Brancher un volant Sega Model 1 ou 2 sur un driving force Logitech
Démarré par Aganyte, Jeudi 19 Novembre 2009, 18:09:32 PM
Vous êtes lourd les mecs, c'est toujours les mêmes questions. Lisez un peu le thread.
Citation de: PaTrYcK le Vendredi 18 Avril 2014, 00:48:00 AM
1)Resistences R1 & R2 there are 3khoms or 10khoms?
2)C1, C2, C3, which voltage is needed?
3) Which frequency you use, 15 or 25khz?
1) It's written on you paper
2) Whatever. Pour les tensions des condos, j'ai ajouté cette note sur le tuto :
"Si la tension n'est pas indiquée pour les condensateurs  , n'importe quelle fera l'affaire."
3) Frequency ??
Citation de: aganyte le Vendredi 18 Avril 2014, 07:58:15 AM
faut traduire ? =:))
PaTrYcK
Hi, thanks for your answer
yes, right, sorry, but unfortunately, I do not know French language and it is difficult for me to follow all the posts
Citation de: Iro le Vendredi 18 Avril 2014, 08:24:45 AM
3) Frequency ??
1) yes, i see it but maybe there is an error, in the paper i read "marron noir rouge or", this is 1khom:
also in the photo i see that resistence R1 & R2 with 10khom value (have orange, not rouge):
2) ok for the tension
3) yes, 15 or 25khz frequency?
Thanks!
siantic
1) Tu as raison. Je le change dans le tutoriel. La bonne valeur est maintenant 3kohms
3) Une fréquence pour quel composant ?
do you mean the frequency of the screen of the cab?
never heard of frequency for the component in the L2M2
there was a mistake for the two resistances
now you can put 3 - 5 kohm in order to get all the details of the road
PaTrYcK
Citation de: Iro le Vendredi 18 Avril 2014, 11:24:11 AM
Ok perfect!
Citation de: zebassprophet le Vendredi 18 Avril 2014, 13:55:06 PM
yes, freq of screen, you used 15 or 25khz?
Citation de: zebassprophet le Vendredi 18 Avril 2014, 13:55:06 PMthere was a mistake for the two resistances
ok, i have ready 3,3k, now installed it, thanks!
diaowee
Can you please explain why the 5Kohm potentiometers will work with the logitech steering wheel and pedals?
Why do they change to 50 and 100Kohm potentiometers when they do the happ/logotech hack? I have measured the potentiometers from my logitech driving force EX and they are 50 and 100Kohm. I think its weird that it should work with 5Kohm when the original ones are 50 and 100Kohm.
I think its especially weird for the pedals which does not run through the L2M2 PCB.
Tu peux que je t'explique ce qu'est un diviseur de tension  =?= Ça marche et c'est tout  >:D
it work with the original trimmer
Why do you want to replace them...
you can configure the pedal in the logitech control panel then no need to change the trimmer
For the screen, depending on your... screen
i've a tv then 15khz
if you have the orignal cab with the original screen 24khz
voili voilou
don't piss off aganyte or he will haunt you during your sleep  :ang:
C'est parce que tu n'as pas vu ma boîte mail, je me demande si certains lisent les tutos....
Citation de: Iro le Mardi 22 Avril 2014, 12:54:11 PM
Depuis quelque temps, Aganyte a ces ragnagnas :D
me l'enervez pas, attendez que j'ai finit avec ma borne^^
autrement, le tuto il a été traduit?
sinon je peux essayer d'en faire une traduction (avec relecture de ma femme^^)
Citation de: zebassprophet le Mardi 22 Avril 2014, 15:01:17 PM
Fais toi plaisir, si ça peut limiter les questions cons superflues.
CryingFreeman
Les gens n'ont qu'à parler francais pour changer un peu.... <:)
