Topic des jeux indépendants
Démarré par harpinos, Vendredi 08 Octobre 2010, 23:12:51 PM
CuBe
Bon normalement le serveur est opérationnel!
Voici l'IP : 82.228.24.149:25555 (Oubliez pas le port sinon vous risquez de pas atterrir sur le bon serveur ^^)
Le serveur risque juste de couper vers les minuit pendant 10 minutes et après il restera allumé H24
WIP Cocktail PacMan Midway :D
RoadTrip New Astro City
Recherche :
-Metal Slug 5
-Thunder Hoop
Citation de: CuBe le Lundi 07 Février 2011, 23:02:06 PM
java.net.NoRouteToHostException: No route to host
at java.net.PlainSocketImpl.socketConnect(Native Method)
at java.net.PlainSocketImpl.doConnect(PlainSocketImpl.java:333)
at java.net.PlainSocketImpl.connectToAddress(PlainSocketImpl.java:195)
at java.net.PlainSocketImpl.connect(PlainSocketImpl.java:182)
at java.net.SocksSocketImpl.connect(SocksSocketImpl.java:366)
at java.net.Socket.connect(Socket.java:529)
at java.net.Socket.connect(Socket.java:478)
at java.net.Socket.<init>(Socket.java:375)
at java.net.Socket.<init>(Socket.java:218)
at jg.<init>(SourceFile:94)
at qw.run(SourceFile:23)
Pourtant je ping correctement l'IP du serveur...
KodeIn
Pareil, impossible de me connecter.
Mais l'erreur est légèrement différente  ;)
7/02/11 23:29:53 [0x0-0x2fa2fa].com.Mojang Specifications.Minecraft.Minecraft[25604] java.net.SocketException: Network is unreachable
7/02/11 23:29:53 [0x0-0x2fa2fa].com.Mojang Specifications.Minecraft.Minecraft[25604] at java.net.PlainSocketImpl.socketConnect(Native Method)
7/02/11 23:29:53 [0x0-0x2fa2fa].com.Mojang Specifications.Minecraft.Minecraft[25604] at java.net.PlainSocketImpl.doConnect(PlainSocketImpl.java:333)
7/02/11 23:29:53 [0x0-0x2fa2fa].com.Mojang Specifications.Minecraft.Minecraft[25604] at java.net.PlainSocketImpl.connectToAddress(PlainSocketImpl.java:195)
7/02/11 23:29:53 [0x0-0x2fa2fa].com.Mojang Specifications.Minecraft.Minecraft[25604] at java.net.PlainSocketImpl.connect(PlainSocketImpl.java:182)
7/02/11 23:29:53 [0x0-0x2fa2fa].com.Mojang Specifications.Minecraft.Minecraft[25604] at java.net.SocksSocketImpl.connect(SocksSocketImpl.java:432)
7/02/11 23:29:53 [0x0-0x2fa2fa].com.Mojang Specifications.Minecraft.Minecraft[25604] at java.net.Socket.connect(Socket.java:529)
7/02/11 23:29:53 [0x0-0x2fa2fa].com.Mojang Specifications.Minecraft.Minecraft[25604] at java.net.Socket.connect(Socket.java:478)
7/02/11 23:29:53 [0x0-0x2fa2fa].com.Mojang Specifications.Minecraft.Minecraft[25604] at java.net.Socket.<init>(Socket.java:375)
7/02/11 23:29:53 [0x0-0x2fa2fa].com.Mojang Specifications.Minecraft.Minecraft[25604] at java.net.Socket.<init>(Socket.java:218)
7/02/11 23:29:53 [0x0-0x2fa2fa].com.Mojang Specifications.Minecraft.Minecraft[25604] at jg.<init>(SourceFile:94)
7/02/11 23:29:53 [0x0-0x2fa2fa].com.Mojang Specifications.Minecraft.Minecraft[25604] at qw.run(SourceFile:23)
CuBe
Réessayez. Je viens de déplacer le serveur, il était plus branché ^^'
Recherche :
-Metal Slug 5
-Thunder Hoop
KodeIn
Ca roule  :D
Pas facile de commencer la nuit par contre, je viens déjà de me prendre un creeper dans le nez  :P
icescream
argh! moi qui viens de mettre en stand bye ma partie solo pour aller me coucher...
faut que j'aille voir ça tant pis pour mon sommeil  :o
Bon, notre petit monde a un peu avancé...  :D
icescream
va falloir créer un topic minecraft si ça continue...
Vais essayer de passer vous faire coucou ce soir :)
CuBe
Bon après si vous trouvez des mods sympa à foutre sur le serveur, vous me dites et j'essayerais de le faire dans la soirée ^^
Recherche :
-Metal Slug 5
-Thunder Hoop
Il existe une démo autre qu'online ?
Qu'elle est la différence avec la béta ?
CuBe
Alors il y a un mode de Minecraft gratuit appelé "Classic" dans lequel tu peux juste empiler des blocs à volonté pour faire toute sorte de construction (En gros du Légo pur et dur). C'est du coup super limité.
La version Beta est la version payante appelée aussi "Survival". Dans ce mode de jeux, tu n'as pas les blocs à volonté, il faut les récupérer dans le niveau et les transformer pour les utiliser comme outils par exemple. C'est le "crafting". Le deuxième ajout de ce mode est l'apparition de monstres la nuit et d'animaux la journée. On peut récupérer du jambon sur les porcs et le faire cuire pour regagner de la vie, récupérer du cuir sur les vaches pour se faire une armure et plein d'autres choses avec des animaux allant du canard au mouton. Il faut aussi s'abriter la nuit pour éviter de se faire bouffer par un zombie ou une araignée géante, se faire tirer dessus par un squelette avec un arc ou encore se faire exploser par un "creeper". Certains courageux se font des armures et des épés pour aller se battre et survivre sans se cacher.
En gros le fossé entre la version gratuite et payante est tout simplement énorme et les 2 versions n'ont au final pas grand chose en commun à part le fait de pouvoir récupérer et poser des blocs
Recherche :
-Metal Slug 5
-Thunder Hoop
OK <:)
Disons que j'aimerais bien essayer avant de dépenser 15€.
Pas sur que j'accroche.
CuBe
Regarde les vidéos sur le net ça donne déjà une bonne idée du jeu
Recherche :
-Metal Slug 5
-Thunder Hoop
Bah j'ai déja vu des videos. Mais sans y jouer , j'arrive pas du tout à me faire une opinion.
wikee
je pense que le topic de base a un peu dérivé :)
je plussoie donc pour l'ouverture d'un topic minecraft, et ca attirera aussi peu etre des curieux   :ang:
New Astro City & Jeutel
