Dealextreme - jamma
Démarré par sdf_, Mercredi 08 Avril 2015, 09:29:07 AM
sdf_
Je ne sais pas si vous aviez vu, où si ce n'est pas utile...
En naviguant sur mon site chinois, je suis tomber la dessus..
http://www.dx.com/p/gbs-8118-arcade-game-2-in-1-remote-switch-control-jamma-pc-board-jamma-switcher-green-376199
Connaissez-vous ? Cela peut il servir ?
Introduction:
Now you can plug 2 different Jamma PCB into one cabinet and select the game you want to play with the press of a switch control .To install just plug the PCB into your existing Jamma harness. It install easily and working perfect.
    Install two different JAMMA (or non-JAMMA with the use of a JAMMA Adapter) PCBs into a single JAMMA cabinet with ease! This 2-in-1 MultiJAMMA switcher board is simple to install and works with just a quick press of the button. Included is a wired switch function.
This 2-in-1 MultiJAMMA Switcher board operates differently than the larger 6-in-1 MultiJAMMA Switcher board. First, both slots (1 & 2) are simultaneously powered on together unlike the 6-in-1 switch will only power on a single slot at once. This provides seamless quick switching between the two installed boards. Also this is a must if installing in a public game room (so the customer does not have to wait for the second game board to power on and test itself if selected...the game would already be up and ready to go).
    Feature:
    All of our items are Brand New
    Multiple input options (Inputs through JAMMA slots, VGA connections, RGB-S Connections, and L/R Audio inputs)
    On initial power up, slot 1 automatically is enabled and plays.
    Both slots power on together
    Switcher routes +5VDC, +12VDC, and -5VDC
    Switcher routes SERVICE & TEST button functions, plus up to 4 shooter buttons per player
    Setup is quick and easy
    Setup Introduction:
    Install the 2-in-1 MultiJAMMA Switcher PCB into your JAMMA ready arcade cabinet (on cabinet floor is ideal if possible)
    Connect the 2-in-1 MultiJAMMA Switcher PCB into your JAMMA cabinets connector
    Install your other JAMMA PCB (or non-JAMMA PCB with the use of a JAMMA Adapter) into one of the open 2-in-1 MultiJAMMA Switcher PCB slots (Slot farthest from the JAMMA connection is slot 1 / closest is slot 2). When plugging in the Jamma boards the front of the board (Front has the monitor port on it) goes to the front of the switch, the front of the switch has the two VGA input ports.
    Power on your cabinet and enjoy
    Important Reminder:
    Technical Notes: This switcher will not switch the video with the 400-in-1 Pandora V2 PCB board using VGA video. In order to work with this board the VGA video need to be manually switched using a VGA switch box. Short of the video needing to be switch on a separate switch all other functions will switch properly. If you are using a CGA tube monitor then there is no issues.
    Monitor: If you are using a CGA monitor then you simply wire the monitor off of the Jamma harness, If you are using a VGA monitor then you have to set your Jamma boards to VGA then plug both of your Jamma boards VGA ports from the boards to the VGA input of the switch using a male to male VGA cord.
sushy18
La question  que je me suis posé  en regardant cette article... c'est vu les différences de voltage aux bornes du connecteur jamma selon qu'il possède 2,3 ou 4 etages.... chui pas sur que va fonctionner avec des cartes énergivore. ..
(:x
sdf_
Je ne m y connais pas assez sur cette problématique de tension..
Ce que j'ai vu aussi c'est qu'apparemment il y a un vga out .. peut être pour adapter du jamma vers VGA directement ? (je ne sais pas si c'est habituel)
Se méfier des chinoiseries avec leur 5v soudé à la masse  p=)
Vu le prix maintenant des PCBs, leur relative fragilité et pour 2 slots, je ne m'y risquerais pas.
Je garde la mano  :)
sdf_
A ne pas retenir alors.. :)
Au moins c'est vu lol
olschool
J'ai fait un article sur les multi jamma
ce modèle là n'est pas a recommander
MULTI JAMMA QUOI CHOISIR
