Scanline sous groovymame
Démarré par maway, Samedi 20 Octobre 2012, 15:20:20 PM
firestorm
J'oubliais, as-tu crée un nouveau fichier mame.ini avec la commande -cc ?
Pour cela, tu crées un raccourci de ton groovymame, clique droit propriété et tu rajoutes à la fin de la ligne correspondant à la cible -cc (ex: "groovymame.exe" -cc).
Exécute ton raccourci et tu auras un beau mame.ini de ce style :
<UNADORNED0>
<UNADORNED1>
# CORE CONFIGURATION OPTIONS
readconfig                1
writeconfig               0
# CORE SEARCH PATH OPTIONS
rompath                   roms
hashpath                  hash
samplepath                samples
artpath                   artwork
ctrlrpath                 ctrlr
inipath                   .;ini
fontpath                  .
cheatpath                 cheat
crosshairpath             crosshair
# CORE OUTPUT DIRECTORY OPTIONS
cfg_directory             cfg
nvram_directory           nvram
memcard_directory         memcard
input_directory           inp
state_directory           sta
snapshot_directory        snap
diff_directory            diff
comment_directory         comments
hiscore_directory         hi
# CORE STATE/PLAYBACK OPTIONS
state
autosave                  0
playback
record
mngwrite
aviwrite
wavwrite
snapname                  %g/%i
snapsize                  auto
snapview                  internal
burnin                    0
# CORE PERFORMANCE OPTIONS
autoframeskip             0
frameskip                 0
seconds_to_run            0
throttle                  0
sleep                     1
speed                     1.0
refreshspeed              0
# CORE ROTATION OPTIONS
rotate                    1
ror                       0
rol                       0
autoror                   0
autorol                   0
flipx                     0
flipy                     0
# CORE ARTWORK OPTIONS
artwork_crop              0
use_backdrops             0
use_overlays              0
use_bezels                0
use_cpanels               0
use_marquees              0
# CORE SCREEN OPTIONS
brightness                1.0
contrast                  1.0
gamma                     1.0
pause_brightness          0.65
effect                    none
# CORE VECTOR OPTIONS
antialias                 1
beam                      1.0
flicker                   0
# CORE SOUND OPTIONS
sound                     1
samplerate                48000
samples                   1
volume                    0
# CORE INPUT OPTIONS
coin_lockout              1
ctrlr
mouse                     0
joystick                  1
lightgun                  0
multikeyboard             0
multimouse                0
steadykey                 0
offscreen_reload          0
joystick_map              auto
joystick_deadzone         0.3
joystick_saturation       0.85
natural                   0
# CORE INPUT AUTOMATIC ENABLE OPTIONS
paddle_device             keyboard
adstick_device            keyboard
pedal_device              keyboard
dial_device               keyboard
trackball_device          keyboard
lightgun_device           keyboard
positional_device         keyboard
mouse_device              mouse
# CORE DEBUGGING OPTIONS
log                       0
verbose                   0
update_in_pause           0
debug                     0
debugscript
debug_internal            0
# CORE MISC OPTIONS
bios
cheat                     0
skip_gameinfo             0
uifont                    default
ramsize
confirm_quit              0
# CORE MKChamp OPTIONS
disable_hiscore_patch     0
disable_nagscreen_patch   1
disable_loading_patch     1
# CORE SWITCHRES OPTIONS
modeline                  1
monitor                   cga
monitor_connector         auto
monitor_orientation       horizontal
monitor_aspect            4:3
monitor_debug             0
monitor_doublescan        1
monitor_dotclock          0
monitor_ymin              0
soundsync                 0
cleanstretch              0
changeres                 1
redraw                    0
monitor_specs0            auto
monitor_specs1            auto
monitor_specs2            auto
monitor_specs3            auto
monitor_specs4            auto
monitor_specs5            auto
monitor_specs6            auto
monitor_specs7            auto
# WINDOWS DEBUGGING OPTIONS
oslog                     0
watchdog                  0
debugger_font             "Lucida Console"
debugger_font_size        9
# WINDOWS PERFORMANCE OPTIONS
priority                  0
multithreading            1
numprocessors             auto
profile                   0
bench                     0
# WINDOWS VIDEO OPTIONS
video                     ddraw
numscreens                1
window                    0
maximize                  1
keepaspect                0
prescale                  1
waitvsync                 1
syncrefresh               1
menu                      0
# DIRECTDRAW-SPECIFIC OPTIONS
hwstretch                 0
# DIRECT3D-SPECIFIC OPTIONS
d3dversion                9
filter                    0
# DIRECT3D POST-PROCESSING OPTIONS
hlsl_enable               0
hlslini                   %g
hlslpath                  hlsl
hlsl_prescale_x           0
hlsl_prescale_y           0
hlsl_preset               -1
hlsl_write
hlsl_snap_width           2048
hlsl_snap_height          1536
shadow_mask_alpha         0.0
shadow_mask_x_count       320
shadow_mask_y_count       240
shadow_mask_usize         0.09375
shadow_mask_vsize         0.109375
curvature                 0.0
pincushion                0.0
scanline_alpha            0.0
scanline_size             1.0
scanline_height           0.7
scanline_bright_scale     1.0
scanline_bright_offset    0.0
scanline_jitter           0.0
defocus                   0.0,0.0
converge_x                0.0,0.0,0.0
converge_y                0.0,0.0,0.0
radial_converge_x         0.0,0.0,0.0
radial_converge_y         0.0,0.0,0.0
red_ratio                 1.0,0.0,0.0
grn_ratio                 0.0,1.0,0.0
blu_ratio                 0.0,0.0,1.0
saturation                1.0
offset                    0.0,0.0,0.0
scale                     1.0,1.0,1.0
power                     1.0,1.0,1.0
floor                     0.0,0.0,0.0
phosphor_life             0.0,0.0,0.0
yiq_enable                0
yiq_cc                    3.59754545
yiq_a                     0.5
yiq_b                     0.5
yiq_o                     0.0
yiq_p                     1.0
yiq_n                     1.0
yiq_y                     6.0
yiq_i                     1.2
yiq_q                     0.6
yiq_scan_time             52.6
yiq_phase_count           2
# PER-WINDOW VIDEO OPTIONS
screen                    auto
aspect                    auto
resolution                auto
view                      auto
screen0                   auto
aspect0                   auto
resolution0               auto
view0                     auto
screen1                   auto
aspect1                   auto
resolution1               auto
view1                     auto
screen2                   auto
aspect2                   auto
resolution2               auto
view2                     auto
screen3                   auto
aspect3                   auto
resolution3               auto
view3                     auto
# FULL SCREEN OPTIONS
triplebuffer              0
switchres                 1
full_screen_brightness    1.0
full_screen_contrast      1.0
full_screen_gamma         1.0
# WINDOWS SOUND OPTIONS
audio_latency             2
# INPUT DEVICE OPTIONS
dual_lightgun             0
maway
Salut, j'ai bien crée le fichier .ini avec le -cc sur le racourci.
J'ai installé windows xp 64 mais impossible d'installer les driver calamity l'installation se passe mais au reboot je suis toujours en 31khz je vais essayer avec un autre xp 64.. Sinon j'essayerais soft15.
Bye.
etralyr
Salut,c'est normal si ton bureau est toujours dans une resolution superieure a 640x480,lance arcadeosd,tu vas voir tout un tas de resolutions  et teste le 320x240 tu devrais avoir le 15khz et donc un ecran noir,appuie sur echap pour revenir a la reso habituelle.
le plus simple ensuite c'est avec quickres,tu selectionne 640x480 et etent l'ordi,tu fait ton branchement sur ta borne et au redemrrage tu sera en 15 khz :)
maway
Le problème c'est Que j'étais déjà en 640 Par 480, je vais réessayer ce soir sinon jessayerais soft15.. Merci.
etralyr
C'bizarre ton histoire,au début de ton topic tout semble bien fonctionner pourtant.
Si le jeu se lance dans sa résolution d'origine et que l'écran scintille pas (tu peut vérifier sous groovymame en appuyant sur la touche windows quand t'as lancer un jeu que la reso correspond bien)quel est le problème?
Ta résolution de bureau qui scintille? mais c'est normal ca comme l'a expliqué machin.
J'me demande si tout ca c'est pas toi qui a une mauvaise interprétation de ce qu'est le 15khz...de toute façon en lançant arcadeosd tu le voit bien si tes reso sont la et que tu peux les sélectionné.
T'as lancer vmmaker avec son .ini correctement configuré au moins?
Y'a pas de raison que si ca a marché pour tout le monde,toi tu y arrive pas quoi,même chelnov après chépa combien de mois a finalement réussit :D
dapsaille
Citation de: etralyr le Mercredi 24 Octobre 2012, 03:14:47 AM....
Mheuuu ????  :?
à part ça, +1 je pense que dès le début le 15khz tourne bien  :D
maway
En effet j'avais pas compris que l'effet "scanline" était le résultat normal avec Groovymame. Bon, alors tout va bien en fait.  :?
Sinon j'ai juste un problème avec Makaron impossible de le lancer
"Cette application n'a pas pu démarrer car la configuration de l'application est incorrecte"
Merci à vous !
