Auteur Sujet: DualScreen Vertical !  (Lu 4592 fois)
Hors ligne padawan
  • Donneur Invétéré
  • Pratiquement VIP
  • Si vous me cherchez---> Je bidouille ᕕ( ಠ‿ಠ)ᕗ
« Réponse #16 le: Mardi 03 Septembre 2013, 12:48:15 pm »
  • A tu essayer le pivotage via le soft Nvidia (panneau de configuration Nvidia) ?
    qui propose d'autres options que la personnalisation via Windows ?
    Hors ligne dess
    • Confirmé
    « Réponse #17 le: Mardi 03 Septembre 2013, 12:51:14 pm »
  • oui :)
    en fait le pivotage vertical n'est permis que lorsque l'on utilise pas le span global :'(
    je pense qu'il faut taper de ce coté la mais si quelqu'un maitrise le sujet ça pourrait aider
    Per-window options
      216  ------------------
      217
      218  -screen <display>
      219  -screen0 <display>
      220  -screen1 <display>
      221  -screen2 <display>
      222  -screen3 <display>
      223
      224      Specifies which physical monitor on your system you wish to have each
      225      window use by default. In order to use multiple windows, you must have
      226      increased the value of the -numscreens option. The name of each
      227      display in your system can be determined by running MAME with the
      228      -verbose option. The display names are typically in the format of:
      229      \\.\DISPLAYn, where 'n' is a number from 1 to the number of connected
      230      monitors. The default value for these options is 'auto', which means
      231      that the first window is placed on the first display, the second
      232      window on the second display, etc.
      233
      234      The -screen0, -screen1, -screen2, -screen3 parameters apply to the
      235      specific window. The -screen parameter applies to all windows. The
      236      window-specific options override values from the all window option.
      237
      238  -aspect <width:height> / -screen_aspect <num:den>
      239  -aspect0 <width:height>
      240  -aspect1 <width:height>
      241  -aspect2 <width:height>
      242  -aspect3 <width:height>
      243
      244      Specifies the physical aspect ratio of the physical monitor for each
      245      window. In order to use multiple windows, you must have increased the
      246      value of the -numscreens option. The physical aspect ratio can be
      247      determined by measuring the width and height of the visible screen
      248      image and specifying them separated by a colon. The default value for
      249      these options is 'auto', which means that MAME assumes the aspect
      250      ratio is proportional to the number of pixels in the desktop video
      251      mode for each monitor.
      252
      253      The -aspect0, -aspect1, -aspect2, -aspect3 parameters apply to the
      254      specific window. The -aspect parameter applies to all windows. The
      255      window-specific options override values from the all window option.
      256
      257  -resolution <widthxheight[@refresh]> / -r <widthxheight[@refresh]>
      258  -resolution0 <widthxheight[@refresh]> / -r0 <widthxheight[@refresh]>
      259  -resolution1 <widthxheight[@refresh]> / -r1 <widthxheight[@refresh]>
      260  -resolution2 <widthxheight[@refresh]> / -r2 <widthxheight[@refresh]>
      261  -resolution3 <widthxheight[@refresh]> / -r3 <widthxheight[@refresh]>
      262
      263      Specifies an exact resolution to run in. In full screen mode, MAME
      264      will try to use the specific resolution you request. The width and
      265      height are required; the refresh rate is optional. If omitted or
      266      set to 0, MAME will determine the mode auomatically. For example,
      267      -resolution 640x480 will force 640x480 resolution, but MAME is free to
      268      choose the refresh rate. Similarly, -resolution 0x0@60 will force a
      269      60Hz refresh rate, but allows MAME to choose the resolution. The
      270      string "auto" is also supported, and is equivalent to 0x0@0. In window
      271      mode, this resolution is used as a maximum size for the window. This
      272      option requires the -switchres option as well in order to actually
      273      enable resolution switching with -video ddraw or -video d3d. The
      274      default value for these options is 'auto'.
      275
      276      The -resolution0, -resolution1, -resolution2, -resolution3 parameters
      277      apply to the specific window. The -resolution parameter applies to all
      278      windows. The window-specific options override values from the all
      279      window option.
      280
      281  -view <viewname>
      282  -view0 <viewname>
      283  -view1 <viewname>
      284  -view2 <viewname>
      285  -view3 <viewname>
      286
      287      Specifies the initial view setting for each window. The <viewname>
      288      does not need to be a perfect match; rather, it will select the first
      289      view whose name matches all the characters specified by <viewname>.
      290      For example, -view native will match the "Native (15:14)" view even
      291      though it is not a perfect match. The value 'auto' is also supported,
      292      and requests that MAME perform a default selection. The default value
      293      for these options is 'auto'.
      294
      295      The -view0, -view1, -view2, -view3 parameters apply to the
      296      specific window. The -view parameter applies to all windows. The
      297      window-specific options override values from the all window option.
      298
    « Modifié: Mardi 03 Septembre 2013, 13:58:32 pm par dess »
    Hors ligne dess
    • Confirmé
    « Réponse #18 le: Mardi 03 Septembre 2013, 14:39:04 pm »
  • c'est bizarre quand même, ça marche niquel sur windows mais il reste en clone mode sur mame malgré les différentes versions que j'ai téléchargé...
    il y a lui qui y arrive bien mais je pense que c'est parceque le jeu de base tourne sur deux écrans.
    moi je voudrais faire croire à mame que je n'ai qu'un seul écran...
    Hors ligne jcp
    • Hardcore Gamer
    « Réponse #19 le: Mardi 03 Septembre 2013, 15:05:08 pm »
  • 3 écrans, je vois ninjawarriors darius, darius 2 (sagaia)
    3x 288x224
    il est indiqué qu'il existe une version 2 écrans pour darius 2.
    source : system16
    + TX1 et Buggy Boy en 3 écrans ;).
    Hors ligne dess
    • Confirmé
    « Réponse #20 le: Mardi 03 Septembre 2013, 15:06:46 pm »
  • bon j'ai repris le problème autrement : retour en arrière sur la configuration windows pour mettre configurer un seul écran en span horizontal et donc sans lui appliquer de rotation.
    je fais ensuite rotation dans mame
    ça marche bien !
    le petit souci étant que je vais devoir changer l'orientation physique des écran car actuellement : un dans un sens et un dans l'autre c'est moyen ^^ c'est dommage car avec les dalles il y aura un joueur qui verra moins bien que l'autre :(
    je me suis fait un torticoli avec ces conneries moi ^^
    ps : c'est vraiment dommage que windows ne prennent pas en compte l'orientation des ecrans lors de la configuration du span
    Hors ligne antoweb
    • Confirmé
    « Réponse #21 le: Jeudi 27 Mars 2014, 10:59:56 am »
  • Et pourquoi pas un ecran 16/10 et mame en mode cocktail ?
    Comme ceci:
