RetroBat V8 - EmulationStation Portable pour Windows
Démarré par lorenzolamas, Dimanche 28 Juillet 2019, 15:02:06 PM
lorenzolamas
#32
C'est avec un peu de retard que je vous annonce l'arrivée de la nouvelle version de Retrobat, qui passe en V8 (même en 8.0.1 aujourd'hui...)
CitationRetroBat is now fully x64 : both EmulationStation and EmulatorLauncher !
### Emulators\cores
  Add Enterprise system (with libretro ep128)
  Add LaserActive system (with ARES emulator)
  Add cassettevision (with libretro pd777)
  Add Elektronika BK (with libretro-bk)
  Add ghostship (mario 64 port)
  Add jzintv (Intellivision)
  Add libretro-supermodel
  Add groovymame (mame specific for CRT)
  Add libretro Azahar core and removed old citra core
  Bump RETROARCH to 1.22.2 (including cores)
  Bump Azahar to 2125
  Bump demul to version from 20/12/2025
  Bump Dolphin to 2603a and add triforce (also to libretro-core)
  Bump Duckstation to 0.1.10693
  Bump Flycast to 2.6
  Bump Gopher64 to 1.1.13
  Bump JGenesis to 0.11.1 (and add gba system)
  Bump MAME to 0.286
  Bump PCSX2 to 2.6.3
  Bump PPSSPP to 1.20.1 (including libretro core)
  Bump RPCS3 to 0.0.40-19146
  Bump RMG (Mupen64) to 0.8.9
  Bump ScummVM to 2026.1.0 (incl. libretro core)
  Bump ShadPS4 (v15)
  Bump Xemu to 0.8.134
  Bump xenia-canary
  Bump xenia-edge
  Bump Yabasanshiro to 1.18.21
  Compatible with Final Citron release
  Compatible with Eden 0.2.0 : Retrobat will add roms\switchupdates folder for external content, but will not erase values set by user
  Remove Demul-old
  Remove Suyu
  Add .hdv extension to APPLE2 and APPLE2GS
  Add .squashfs to sgb-msu1 and snes-msu1
  Add .bigpimg to jaguarcd
### Fixes
  3DS: fix language with citra and libretro-citra
  APPLEWIN: add joystick option
  Ares: fix mapping of xinput controllers for right-stick and triggers
  Ares: fix mapping of 8BitDo M30 for megadrive
  BigPEmu: fix xbr-lv3 filter
  DESMUME: fix analog stick mapping
  DHEWM3: fix duplicate save folder path
  DOLPHIN: texture pack load path moved to saves\<wii or gamecube>\dolphin-emu\User\Load ==>  you need to move them
  EDEN: fix controller configuration for xinput
  EPIC: fix launch with new version of EPIC
  LIBRETRO-MAME: fix savepath and statepath when emulating MESS machines with softwarelist
  MAME: fix mortal kombat series gamepad mapping
  MAME: fix a potential error message if bios\mame\ini folder does not exist
  MAME: improve lightguns management
  MODEL3: invert controls for Star Wars Trilogy analog controls
  OPENBOR: remove RetroBat reshade
  OPENMSX: fix launch of machines with bios in bios\openmsx
  PCSX2-16: fixed bios detection
  REDREAM: fix potential error message when quitting emulator
  RETROARCH: fix error message when using wheels
  RETROARCH: RetroBat will now clean previous controller hotkeys before resetting them
  RYUJINX: detect sdl2 or sdl3 version and set audio driver accordingly
  SCUMMVM: fix launch of squashfs games
  SINGE2: fix launch (was broken when we updated hypseus and folder naming)
  STARSHIP: fix error at launch
  TEKNOPARROT: tentative to fix 'access denied' when exiting games
  TEKNOPARROT: fixed inversion between windowed and fullscreen format in features
  TEKNOPARROT: add missing bezels feature
  TEKNOPARROT: make tatsunoko vs capcom launch from Teknoparrot folder
  TEKNOPARROT: Fix issues with some games path not found when no executable is specified in gameprofile (Offroad Thunder for example)
  TEKNOPARROT: filter keyboards that has same VIDPID than a mouse/gun for defining the default keyboard to use for gun games
  VPINBALL: fix "out of array" error message when screenres.txt has less than 17 lines
  VPINBALL: also kill PinUpDisplayX on exit
  XASH3D: fix start of engine
### Features
  APPLE2: add some slot options when using MAME\LR-MAME (ramsize, cffa2 module, -hard1 media)
  AZAHAR: add some audio options and cemuhook as touch device option
  BIGPEMU: add possibility to use duimon shaders from RetroBat shader-list
  CAP32 (libretro): added per-game mapping through json file
  CEMU: add option to launch separate gamepad window as default
  DOLPHIN: log special controller profiles when used
  DOLPHIN: Multi-core is disabled by default (instead of enabled by default)
  DOLPHIN: add fallback to dinput if controller is not known by SDL
  DUCKSTATION: add option for custom textures
  EDUKE32: add few options (vsync, ...)
  GAMEBOY and GBA: added option to invert face buttons
  IKEMEN: enable bezel feature to be able to disable them
  IKEMEN: Add additional resolution options
  LIBRETRO-DOLPHIN: add manual texture sampling option
  LIBRETRO-dosbox_pure: notifications were disabled by default: this is removed now to align with all other cores
  LIBRETRO-melondsds: Only 2 screen layouts are allowed and can be independently selected
  LIBRETRO-MESEN: add SNES mouse and SNES controller options
  MAME: add option to disable crosshair
  MEDNAFEN-SNES: added option to invert face buttons (was missing)
  MELONDS: add xbox layout
  MESS: added possibility to add a .commands file in order to specificy your own command lines
  MGBA: add controller autoconfiguration
  PCSX2: allow custom crosshair path definition
  PROJECT64: add graphics features + custom textures (to be placed in saves\n64\project64\hires_texture) + raphnet dll for raphnet adapters
  RETROARCH: allow kb hotkey override even with autoconfig disabled
  RETROARCH: added new layout for NES (Xbox layout)
  RETROARCH: RetroBat-provided game remaps (for arcade) will now generate a "Core" remap file (or content folder for MAME) instead of a "Game" remap file, if you have your own game remap file, the latter will have priority
  RETROARCH: add ability to override custom aspect ratio with a .txt file in json format
  RETROARCH: add possibility to autoconfigure arcade devices detected as keyboards (e.g. IPAC2), for now only IPAC2 and Tankstick are provided
  RETROARCH: Add unzipping for psx, saturn and pcenginecd
  RPCS3: add a few missing features
  RPCS3: add access to rpcs3 menu overlay with shortcut select+SOUTH
  LIBRETRO-VICE: add gun options
  SNES-MSU1 and SGB-MSU1: add squashfs support
  SWITCH: desynchronize features between EDEN and CITRON
  SWITCH: Remove option to mutualize sdmc, nand and load folders for yuzu forks (was generating issues), replaced with option to use saves\switch\ folder for citron and eden saves (for the people that had the mutualization option, you will need to copy your saves to new folder)
  TRIFORCE: add option to add patches from RetroBat interface
  TSUGARU: add padtokey and fix bezels
  WHEELS: add logitech G923X autoconfiguration for m2emulator (model2)
  WII: added retroachievements for Dolphin and lr-dolphin
  VITA3K: add custom textures options (place textures in emulators\vita3k\textures\import)
  VPINBALL: remove F12 assignment to tweakKey, moved to F10
  YMIR: add bezels
### Other stuff
  Emulatorlauncher and EmulationStation are now x64
  Added a keyboardhook to enable intercepting keyboard keys : for example to quit model2 emulator using ESC
  Add guitar autoconfiguration with guitar class : so far only CKRD guitar in pcsx2
  Renamed systems: sonicmania to sonic-mania, sonic3air to sonic3-air, snes-msu to snes-msu1, gb-msu to sgb-msu1, o2em to odyssey2, casloopy to loopy (this means change of rom folder names and for themes)
  THEMES: renamed imageviewer to screenshots
  CONTROLLERS: Add GameSir T4 Kaleid in gamecontrollerDB
  CONTROLLERS: Fix autoconfig for 8bitDo N64 in RetroArch n64 cores
  CONTROLLERS: JoyCon pairs now work with Citron, DuckStation, Eden, Mupen64, PCSX2, Ryujinx (but RetroArch does not seem to accept these)
  EMULATIONSTATION: add Control Center (available with hotkey + EAST)
  EMULATIONSTATION: update rcheevos library (will fix PSP not indexing)
  EMULATIONSTATION: Add ability to disable scraper services
  HOTKEYS: Hotkeys for Ares, BigPEmu, Bizhawk, DesMume, Dolphin, Duckstation, Flycast, JGenesis, Mednafen, MelonDS, Mesen, PCSX2, PPSSPP, Project64, Raine, Snes9x and RetroArch can now be overriden(files retroarch_controller_hotkeys.yml and retroarch_kb_hotkeys.yml must be renamed to controller_hotkeys.yml and kb_hotkeys.yml)
  HOTKEYS: Align as much as possible default keyboard hotkeys of Ares, BigPEmu, Bizhawk, CGenius, Demul, Desmume, Dhewm3, Dolphin, Duckstation, Flycast, Hatari, JGenesis, MAME, Mednafen, MelonDS, Mesen, Mupen64 (RMG), OpenMSX, PCSX2, PPSSPP, Project64, Raine, Snes9x and RetroArch
  MAME: add some games to auto-config templates
  RETROBAT: new logo and colours for V8 (we will try to update on a yearly basis)
  RETROBAT: Add option to start a random Theme
  RETROBAT: add ability to merge folders when updating
  RETROBAT: fallback on retrobat.org for update if main server is not available
  RETROBAT: installer will not propose prerequisites if they are already installed
  RETROBAT: refactor exelauncher to make it more readable
  RETROBAT: update installer executable
  TATTOOS: display tattoo even when autoconfigure if OFF (only when tattoo file is in user\inputmapping folder)
  THEME: changed naming of some systems: boom3 to doom3, vitaquake2 to quake2 and tyrquake to quake
changelog v8.0.1:
Citation### Emulators\cores
  • Bump OpenGoal to allow jak3
  • Bump Xenia-Manager and Add Xenia-Manager cores (netplay/mousehook/canary)
  • Add amiarcadia core for VC4000 and Arcadia 2001
  • Add .m3u extension to atari800 system
  • Add .ags extension to amiga500 system (use it to point to the AGS folder to enable launching AGS from RetroBat)
  • Add exodos, exowin3x and exowin9x systems (grouped with DOS / windows): set the path to your exodos/exowin folders and RetroBat can scan your exodos/exowin games.
### Fixes
  • BATGUI: change sdl versions to x64 when using the reset SDL version
  • DOLPHIN: fix update detection
  • DOLPHIN: fix wii and nunchuk shake and swing mappings (only Z axis was mapped)
  • EDEN: ensure eden-cli process is closed when closing eden
  • EMULATORLAUNCHER: fix decompression of 7z games
  • EMULATIONSTATION: fix various interface/navigation bugs & improved navigation performance
  • LIBRETRO-MAME: apply default config only for mame, not MESS systems
  • MEDNAFEN: fix generator crashing
  • MODEL3: fix gun controls and starWars trilogy mouse
  • TEKNOPARROT: for namco3xx (RPCS3), set write color buffer to true if the game is a gun game
### Features
  • Add a general option to disable pausing emulators when focus is lost
  • LIBRETRO-DOSBOX_PURE: add option for L3 button action (virtual keyboard or menu)
  • DUCKSTATION: add alpha blending to internal bezels (this avoids game image to appear over the bezel on the edges)
  • GROOVYMAME: separate ini folder versus MAME
  • GROOVYMAME: add vertical profile for lcd in portrait mode
  • EMULATIONSTATION: if cancel and confirm buttons are inverted in developer settings, the Game Control Center and the Installer Form will adapt
  • RPCS3: more robust way to manage m3u (look in all folders and send command only if file actually exists), no need to modify your .m3u anymore !
  • TEKNOPARROT: add input mappings
### Other stuff
  • UPDATE: do not check for emulator updates if RetroBat is not up to date
  • EMULATORLAUNCHER: add ESC key to close model2 and rpcs3 emulators
lorenzolamas
Salut !  :laugh:
Retrobat V 8.2.0 Changelog
### Emulators\cores
Replaced Caprice Forever 64 with Caprice Forever 32 and add bezels
Add PCSX2X6 fork to run Namco246 and Namco256 games (standalone and through Teknoparrot)
Add libretro-ymir for saturn
Add .rvz extension to dusklight
Bump Dolphin to 2606
Bump Duckstation to 0.1.11295.0 (may 10, 2026)
Bump Hypseus Singe to 2.12.0
Bump JGenesis to 0.13.0
Bump MAME to 0.288 (standalone, groovymame and libretro)
Bump RAINE to 0.97.5
Bump RPCS3 to 0.0.41-19521
Bump ShadPS4 to 0.16.0 (mandatory update - previous version won't work anymore)
Bump ScummVM to 2026.3
Bump libretro-virtualjaguar and add to jaguarcd
Bump Vita3K to 0.2.1.4058
Bump Xemu to 0.8.136
Bump Xenia to feb 18, 2026
Bump Xenia-canary to june, 29 2026 build
Bump Xenia-edge to june, 29 2026 build
Bump Xenia-manager to 4.2.2
Bump Yabasanshiro to 1.20.32
Bump Ymir to 0.3.3
Bump Libretro-Supermodel to 0.2.0.0
### Fixes
DOLPHIN-TRIFORCE: fix version check
EMULATIONSTATION: fix bezels menu strange spacing
EPIC: fix automatic game shortcut creation
FLYCAST: fix gun not being configured correctly when demulshooter is set
GOPHER64: fix RetroAchievements login from RetroBat by sending command lines
MAME: fix sf2ce launch
MUPEN64 (RMG): fix 8bitDo n64 controller mapping
RAINE: option to disable pause on focus lost does now work in RAINE
SCUMMVM: less rigid in reading .scummvm file content (eg will not fail if the file has a second empty line)
STEAM: fix ;gameexe usage with Steam games
TEKNOPARROT: fix forcing windowed mode
TEKNOPARROT: fix demulshooter for rpcs3 namco3xx arcade games
VITA3K: fix fullscreen when launching from RetroBat
VPINBALL: change select+start action to WM_CLOSE instead of ESC and add option to start with -minimize option + option to send gameexit key instead of WM_CLOSE
LIBRETRO-MELONDSDS, MELONDS and BIZHAWK: Add option to define dsi_nand file region (for nds system)
LIBRETRO-OPERA: fix nvram storage option
HOTKEYS: fix case where user-defined hotkeys would not work if duplicate values
INSTALLER: fixed check for dx9
RETROBAT: fix issue with breaking symlink when uninstalling game from store whe roms folder is symlinked
### Features
DOLPHIN (standalone and libretro): add option to enable immediate xfb presentation (useful for some wii games to remove the green bar at the bottom)
DUCKSTATION: allow multigun with raw input
GAMEBOY: add option to remap select to other button (useful for games requiring to press select + start like Link's Awakening)
HYPSEUS: add stretch option to stretch game image to screen, ignoring game ratio
LINUXLOADER: add sindenborder shader
MAME: add autoboot from lua scripts (camplynx, bbcmicro, cdi, crvision, electron, vg5k)
MODEL2: enabled gun configuration (demulshooter, etc.) even if controller autoconfiguration is off
MODEL2: add ability to perform wheel mapping by wheel type + rom name and add mapping for LogitechG923PS wheel
RPCS3: Add squashfs support for PSN games
RPCS3: Add feature to manage libraries (added 1 library for def jam icon)
RPCS3: Add feature to select how config files should be managed (by default it will use the config database)
RYUJINX: change generator so that non-SDL controllers are more likely to be configured correctly
SHADPS4: place home_dir in saves\ps4\shadps4\home (old saves will need moving)
TEKNOPARROT: add reshade for elfloader x64
TEKNOPARROT: add ability to perform mapping for arcade stick layouts
WINDOWS: add ability to put 2 processes in .gameexe files, RetroBat will monitor the 2nd process listed when the first one exits
LIBRETRO-BLUEMSX: add cart mapper option
LIBRETRO-MAME: add option to use own user .cfg file for MESS while still configuring RETROARCH controls
LIBRETRO-MAME2003: add option to select mouse device
LIBRETRO-MEDNAFEN_PSX_HW: fix PGXP option
LIBRETRO-SUPERMODEL: add powerpc frequency
### Other stuff
Added a .bat tool to index RVZ (wii and gamecube) games for RetroAchievements (in retrobat\system\tools)
Guns: allow to run demulshooter when autoconfig and use-guns is off in RetroBat
Update mountsquashfs tool to fix some issues with RPCS3 saving (aderummier)
Add possibility to manage separately wheels and shifters (nothing happens yet, we need people with separate shifters to finalize)
Multiple features fixing
