Question sur jamma
Démarré par jamesmustain, Lundi 08 Février 2021, 06:51:41 AM
jamesmustain
The Pros And Cons Of Upright Vacuum Cleaners
Most of the highest rated vacuum cleaners on the market nowadays are upright and canister vacuums - which is easy to understand, because many households prefer these two vacuum types compared to others.
In this post, we will focus on the advantages and disadvantages of upright vacuums, so you can have a clear overview of this vacuum model. Hopefully, our short upright best vacuum cleaner reviews will solve your dilemma of choosing the right vacuum for your house
The pros of upright vacuum cleaners
#1: They are easy to use
The integrated design of upright vacuum cleaners makes it easier to move from one room to another. As they have the handle accompanied, you don't need to bend down to reach the Best Rated Vacuum Cleaners. You can push, pull or carry the entire device with only one hand.
#2: They won't take up too much space
Upright vacuums can be put anywhere: in a closet, mudroom, garage, or wherever as long as there is enough space. Some models even offer customized tools to pin the vacuum on the wall to help free up floor space.
#3: They are easy to clean
Most models of upright vacuum cleaners are bagless, consist of plastic containers that can be snapped into place. This comes in handy as once you are done collecting all the dirt and debris, this will make them easier to be cleaned.
#4 They have pretty large heads
Large vacuum heads that help upright vacuums balance on their own are also convenient for vacuuming large spaces. The large footprint allows users to clean every room quickly and easily.
The cons of upright vacuum cleaners
#1: They can be noisy
The sound produced by upright vacuums is always louder than that of canister vacuums. Although there are still less noisy upright vacuums on the market, with the noise around 70 decibels. But generally speaking, its integrated design makes it difficult to eliminate the sound that the engine produces.
#2: They are less flexible
Unlike the canister model, upright vacuums cannot reach all edges in your house. Of course, you can use extra tools and accessories, but it's still difficult to reach out to the back or surroundings of your furniture. The stairs also pose great problems to upright vacuums. They require the users to lift the vacuum's heavy frame along the stairway. Additionally, the spacious head can be larger than the stairs themselves, which can make the vacuum hard to balance.
#3: Their weight might pose a great concern
The average weight of most upright vacuums is approximately 20 lbs, which is not too heavy provided that you don't need to lift and move them between different places regularly. Yet, their weight can cause trouble for weak users or the elderly, especially if they need to vacuum for a long time. Therefore, if you have concerns about the weight, a cordless vacuum cleaner will be more suitable rather than an upright one.
Final Words:
Above are some advantages and disadvantages of upright vacuums you should note when shopping for the best vacuum cleaners.
Besides these notes and with Top vacuum cleaners reviews, you should take into consideration your cleaning needs, budget, and house space so as to have the best vacuum choice for your house.
Bienvenue à toi !  ^-
Le Français est-il ta langue maternelle ? Je me permets cette interrogation car je ne comprends rien à tes questions ! ;)
Dans le reste de mon message, je mets en gras les termes que je ne comprends pas ;).
Si tu ne parles pas Français, il vaut mieux poster tes messages dans ta langue maternelle, ou mieux, en Anglais :).
Citation de: jamesmustain le Lundi 08 Février 2021, 06:51:41 AM
J'ai acheté un terminal de type machine à sous avec jeton et bande de ticket.
Le présent est un jamma tropical v.2
Veux-tu dire que tu as acheté une machine à sous, genre pachislot, ou une borne d'arcade équipée d'un monnayeur à jetons, et distributeur de ticket, ce que les Américains appellent "Redemption games" ?
Le plus simple serait que tu nous postes des photos de ton appareil, afin qu'on comprenne de quoi tu parles.
Pour poster des photos, tu trouveras le tutoriel ici.
Après avoir récupéré la balise jamma est hs.
Parles-tu du connecteur JAMMA de la borne ? Là pareil, mets nous des photos de ce qui ne fonctionne pas :).
