Erreur Guilty Gear X Sega Naomi
Démarré par el_nino, Jeudi 30 Octobre 2014, 12:56:15 PM
Bonjour à tous,
Je viens de recevoir un jeu cartouche NAOMI :
Je retire ma dimm board 4.02 et son lecteur compact flash (...) et voici l'écran :
Etrange ce message d'erreur...je presse sur un bouton, le jeu démarre...je Google et tombe la dessus :
http://www.hyperspin-fe.com/forum/archive/index.php/t-3912.html
Ok so I went through just to see what all games I could get working, and here's a list of all the errors I got:
brddown: no screen past boot screen
cfield: <Data error> (-1006) in module HOLLY/TA: Object List Set
cspike: no screen past boot
cvs2gd: horrible sound
cvsgd: horrible sound
deathcox: startup sound, then nothing
DerbyOC: ERROR02, caution 53 (horizontal 31khz?)
doa2: <internal error> (-1005) in module SH4/r: GILLI @0x0c020012 / 0x8c6f
doa2m: <internal error> (-1005) in module SH4/r: GILLI @0x0c020012 / 0x0a43
dybb99: error02
dybbnao: error02
dygolf: i/o BD connected to naomi bd doesn't fulfill the game specs
fotns: error01
ggram2: internal error (-1005)
ggx: EEPROM ID or Version ERR :: address error (getpallette Address) ~playable
gram2000: file not found [aicadrv.bin]
gundmgd: horrible sound
gundmxgd: horrible sound
hmgeo: broken graphics
ikaruga: no screen after boot
karous: caution 51
keyboard: dataerror (-1006) unknown type S:7
kurucham: dataerror (-1006) unknown type S:7
lupinsho: nothing after boot
meltyb: <Data error> (-1006) in module HOLLY/TA: Object List Set
meltyba: <Data error> (-1006) in module HOLLY/TA: Object List Set
moeru: dataerror (-1006) unknown type S:7
monkeyba: no screen after boot
mvsc2: freeze on loading now screen - Internal error (-1005) in HOLLY/MMAP: ZR: Invalid address
otrigger: nothing after boot
pstone: "now loading" flashes and board resets
pstone2: freeze at text title
puyofev: <Data error> (-1006) in module HOLLY/TA: Object List Set
qmegamis: <internal error> (-1005) in module HOLLY/MMAP: zapisrej: STARTRENDER - HOLLY/PVR.RENDER (on 'start')
senko: dataerror (-1006) unknown type S:7
senkoo: dataerror (-1006) unknown type S:7
shanrgil: <internal error> (-1005) in module HOLLY/MMAP: zapisrej: STARTRENDER - HOLLY/PVR.RENDER
smarinef: <internal error> (-1005) in module HOLLY/MMAP: zapisrej: STARTRENDER - HOLLY/PVR.RENDER
spawn: broken gfx
ss2005: dataerror (-1006) unknown type S:7
suchie3: I/O Board unsupported
tetkiwam: no screen after boot
usagui: dataerror (-1006) unknown type S:7
vathlete: choppy gfx / sound
virnba: <internal error> (-1005) in module HOLLY/MMAP: zapisrej: STARTRENDER - HOLLY/PVR.RENDER
virnbao: <internal error> (-1005) in module HOLLY/MMAP: zapisrej: STARTRENDER - HOLLY/PVR.RENDER
vs2_2k: <internal error> (-1005) in module HOLLY/MMAP: zapisrej: STARTRENDER - HOLLY/PVR.RENDER
vstrik3: error01
vtennisg: <Internal Error> (-1005) in module SH4/r: GILLI @0x0c000600 / 0x05e0
wsbbgd: no screen after boot
zombrvn: constant resets
and this isn't including the vertical oriented games...
Alors défectueux ou pas mon jeu ?
Et quand tu appui sur le boutton Test de CM ça donne quoi ?
juju49
#2
C'est pas un problème de Bios  =?=
Il faut un bios Jap/US
C'est justement l'idée que j'ai eu après une partie  :D
"Sample Game in export"  :-X
Le game test mode  :?
Sinon le dessous de la cartouche :
C'est normal cette résistance ?
Citation de: juju49 le Jeudi 30 Octobre 2014, 13:16:23 PM
D'après le dossier Neo Arcadia : http://www.neo-arcadia.com/dossier/dossiers-techniques/sega-naomi/les-differents-bios/
GGX tourne avec un bios JAP et US (et non export)
J'ai un bios  EPR-G 21578
qui n'est pas référencé sur http://sega-naomi.com/bios.htm
mais il apparait ceux-ci :
EPR-21578E - Export
EPR-21578H - Export
Mon bios serait donc un bios export ?  :?
Pour moi :
EPR-21576x - Japan
EPR-21577x - USA
EPR-21578x - Export
Avec x étant la version du bios.
Donc oui je pense que tu possède un bios export.
Nouveau test sur une carte mère avec bios JAP : 25176D : même message d'erreur
Test sur Naomi 2 bios 23607B (USA) : même message d'erreur  :?
chacal
#7
j'ai le meme probleme j'ai essayé avec 4 carte mere naomi avec bios E,G et H  >:( peu etre la pile CR2332 =?=
