LINDBERGH YELLOW POWER!!!
Démarré par ggya, Lundi 09 Mai 2011, 17:27:18 PM
CryingFreeman
http://www.sega-naomi.com/forum/viewtopic.php?t=4733&postdays=0&postorder=asc&start=15
Android disait que yavait quand meme moyen de faire tourner du yellow/red sur du blue... mais c'est pas de mon level...
Faudrait que je vois avec Andy combien il prendrait pour me convertir ma blue... MAis je suppose que une changement de cf et un flash de carte graphique devrait suffir dans mon cas... ce qui serait trop cool :)
ggya
Ah tu vas y arriver a faire tourner un jeu sur ta lind
Sinon la cf ya quoi dedans bios os...?
CryingFreeman
CitationHi,
Basically between Blue and Yellow Lindbergh, the are tree main Differences:
1) Blue Lindbergh boots from a hardware locked 512Mbytes CF card, that contains a Windows XP embeded OS.
2) Yellow Lindbergh boots from a hardware locked 128 Mbytes CF card than contains a Montavista Linux OS.
3) Normally Blue Lindberghs are only Japanish Region and Yellow Lindberghs, can be USA, Export, or Japan Region
Updating the BIOS of the Vga is not a problem, you can use a tool called NVFlash, that runs from MS_DOS and is publically available on internet, try searching mvktech on google.
I run this VGA FLASHING Tools from the Lindbergh itself, booting with a CF that contains MSDOS like Shell, extracted from Win98.
Region Switch is not a problem is a matter of modify a byte inside an External I2C E2prom connected to the MBUS of the Southbridge and recalculate a CRC (This e2prom is the one near to the DIMM Modules)
I succesfully dumped the CF card of the Lindbergh using an external equipment, but for the moment I can not write to the original CF, cause I have some problems recreating a hardware watchdog signal, but I found another way and it should be ready shortly...
The CF of the Lindbergh, uses various messures of security:
1) It needs a special signal sent thru IDE0 Data Bus Lines (D4 and D12) during the IDLE times for initial unlock and keep it alive, if you try a Hotswap after unlocking the CF, it locks automatically.
2) It needs a 32 Bytes Password sent by the Lindbergh with a propietary ATA Command 0x82, during bootup, really the password can be of 256 Bytes, but the Lindbergh only uses 32 Bytes and the rest is filled with 00's.
I made some conversions of Blue in Yellow and Red in Yellow, but using a special CF card, not the original one, because Lindbergh allows to boot from 3 types of CF cards, depending on the CF Manufacturer string stored in the ATA Identify answer.
Lindbergh is able to boot from 3 types of CF, but only sends unlock information to the original one that comes with the Lindberh, that is manufactured by ADTEC.
Andy can help with that, I think he can do conversions of Blue Lindberghs into Red and or Yellow, and also can convert it to export.
So I think you should contact him.
ya plus qu'a voir combien ca va me couter ce genre d'histoire et si on peut faire tourner du yellow et red sur la meme mobo...
macklane
Ca serait vraiment interessant, mais je pense pas que ca soit si simple  :'(
ggya
il faut choisir une couleur je pense aussi k c est plus simple
Moi le jaune ca me va
CryingFreeman
je sais je sais... on me le dit souvent que le jaune c'est ce qu'il y a de mieux  <:)  :ang:
ggya
Et Surtout pour les jeux de bagnole
wikee
Citation de: CryingFreeman le Lundi 16 Mai 2011, 22:45:44 PM
loooool  <:)
New Astro City & Jeutel
ggya
#56
ca y est j'ai enfin une carte 7800GS apres un petit coup de flash ca tourne impecc sur la lind plus de 3D folle.
en haut l'ancienne, en bas la nouvelle
Pensez a moi si vous avez un tuyau pour une FFB bd pour lindbergh  :D
A++
ggya
ouamself
oui mais Android ce n'est pas un petit joueur niveau $$$ (ni niveau compétence)  .. mais du coup c'est curieux, car les chinois savent hacker le système et lui qui a investi plus de 1000$ dans un analyseur spectromachintruc pour étudier la Lindbergh dans ses tripes, n'est pas arrivé à ce niveau des chinois ?!
EK-TOMB
Bonjour, j'ai pas trop compris ce qu'il cherche mais si il arrive a faire un keychip universelle ce serait bien   ^-^
comme dit gyga oui il semble kiffer de sniffer le flux pc des lindbergh.  c'est un louche celuilà  :D,  ah zut, c'est ~10.000$  :( l'analyseur spectrographique qu'il a acheté pour s'amuser
EK-TOMB
bonsoir, si cela lui permet de décrypter les lingbergh et faire des boot chinois lui aussi (cf: les propos de Andy sur le initial d 5 export)    ^-^
