Repair of Sega 839-0213 / 839-0341 PCB
Démarré par berty, Vendredi 26 Juin 2020, 06:42:09 AM
berty
Hi All,
Apologies for not being able to write messages in French. I was attracted to the forum because of the wealth of technical expertise here. I am an Australian collector of mainly 90s dedicated arcade machines. I enjoy fixing and restoring machines. My current project is a G-Loc Deluxe with significant corrosion issues.
I've started working on the 839-0213 PCB. I need to replace all of these components which are labelled as "Z##" but I cannot figure out what they are.
I think they are either a Zener or TVS diode, but I am not sure. The end with the orange bands is connected to +5VDC and the end with the black band is connected to ground.
Can anyone help me identify what these are so I can replace the corroded ones on my board?
Cheers
Good luck.
There is indeed, plenty not good repairer on this site.
Hope your cab will start again
gc339
#3
As these things are numerous, and since they are connected between +5 volts and ground as close as possible to the logic chips, I think that they are rather decoupling capacitors.
The best solution to ensure this,  it's to desolder one of these components and measure it with a chinese multifunction component tester.
Totaly FuRy
Please put better quality photo or with a closer look.
This can be inductors, ferrits or power limitation resistors.
Theses boards seems to be part of Power Drift DX drive board.
I'm agree with gc339, I think that are tubular ceramique capacitors.
They are use for decoupling the power supply from the logical chips
That is an uncommon package for capacitor but whe can find this in some arcade or pinball board
Totaly FuRy
#6
I was on mobile, so the photo was bad looking.
What is the symbole on the silk ?
At first it's look like a diode, maybe a zener diode that will match the Zxx labelling ?
Take a look at the last photo of this thread:
https://www.gamoover.net/Forums/index.php?topic=26958.0
berty
Here is a picture of the PCB at location Z24.
@gc339 - thank you for the suggestion. I just bought one of those Chinese multifunction testers.
The symbol on the PCB look like a TVS biderectional diode, but component istself look like an axial ceramique capacitor??
The only way the make light on this problem is to test the component with a component testeur or multimeter
Totaly FuRy
#9
I think these are "DIAC" biderectional zener diodes, the main goal is to not power circuits if the tension is not above 33V (maybe 3,3V?). This board should drive motors so 33V look legit
Edit: schematics show that motor power is 24 so 33 does not look possible.
https://www.arcade-museum.com/manuals-videogames/S/Sega%20power%20drift%20FINAL.pdf
berty
I've ran the component through two different component testers. Both testers read the component as a 33nf Capacitor! Does this sound right to people?
My first idea was good, no more doubts possible, the components are axial ceramic capacitors of 33nf
The color code match to the reading  3Xorange +1X black = 33X1nF +/-20%
Totaly FuRy
Citation de: Fred G5 le Lundi 06 Juillet 2020, 12:20:33 PM
^-^ good to know
berty
Hi all - I'm having issues finding an exact replacement for the 33nf axial ceramic capacitor. I was able to source some film capacitors but they are too large.
I am wondering if I can use something like what is shown below;
https://www.jaycar.com.au/33nf-50vdc-ceramic-capacitors-pack-of-2/p/RC5354
