[Problème] Borne qui ne s'allume plus et fait disjoncter
Démarré par Darius, Mercredi 15 Août 2007, 13:26:14 PM
Darius
j'ai envie de remplacer l'alimentation de la borne NewGame N styl mais je ne sais pas comment procéder au niveau du cablage quelqu'un la deja fait ?
Darius
voici la reponse d Andy que j'ai recu aujourdhui avec mon email en anglais apres. des idées ?
Darius,
The problem would be a major issue with AC voltage on the frame of the monitor.
This would cause the monitor to sit at a high voltage and be very dangerous. When the J-PAC is connected, this volgate is routed through the J-PAC to the PC and to ground through the PC, which causes the power cut.
This is a very serious situation and don't switch on the cabinet until it has been tested and fixed by someone with electrical knowledge.
Regards
Andy
________________________________________
Sent: 20 August 2007 20:49
To: andy@ultimarc.com
Subject: J-Pac & Tripped
I have Newgame Styl arcade machine with an Hantarex 9110 screen.
I changed it into a MameCabinet with J-CAP adapter from Ultimarc buying recently.
That worked 1 week and a half with the J-CAP.
After playing with it, I just pushed the on-off switch as to turn it off : there was a disconnection, a power cut in the whole house.
I have tested the computer and the machine separatly, both works.
It trips only when I connect the J-CAP with the Jamma connector of the machine.
I made the following tests:
- no connection of the J-CAP
- no connection of the arcade screen
- computer off
->No power cut
- Connection of the arcade screen
- computer off
-> No power cut
-> sound of the screen as to indicate it turned it on : OK
- Connection of the J-CAP
- Connection of the screen of arcade
- computer on, I wait for 2 minutes : There are sounds coming from loudspeakers
- I turn on and the machine and then there's a power cut in the house.
I asked for advice from people in forums but we can't detect the real problem and if the J-Pac can be linked to it.
- connection of the J-PAC without connecting keyboard or screen to computer -> there's no problem.
I tested to connect the keyboard and/or the screen to the Jpac (both) connected to the machine and the computer : a fuse has blown!
WiLL
Citation de: Darius le Lundi 20 Août 2007, 20:23:19 PM
Un ami a testé plusieurs chose, la masse a l'ecran est bonne, par contre sur l'alimentation meme de la borne on a pas le zero absolue, est ce que ca pourrait venir de ca ?
une difference des tension: je m'explique entre la masse de l'ordinateur qui est de zero et la masse de la borne qui n'est pas tout a fait a zero, qui fait sauté le différentiel ? ?
Est-ce que tu as une prise de terre dans ton mur ?
Est-ce qu'elle est bien relié à la terre ? Parce que des prises électriques avec terre alors qu'il n'y a que 2 fils dans le mur c'est fréquent.
Parce que normalement si tu en as une, tous les appareils branchés sur cette prise devraient être au même potentiel.
Si ca ne tenait qu'à moi, j'essaierai de relier toutes les masses dans la borne ... mais bon ... je suis kamikaze peut etre  :-\
Justement, attention aux masses de l'écran, les parties métaliques de celui ci servent de neutre, donc à ne surtout pas brancher à la terre... Et à ne pas brancher avec les masses de la borne non plus...
WiLL
Citation de: high_cobra le Mercredi 22 Août 2007, 13:44:07 PM
Les parties métalliques servent de neutre ???
Sur les PC elles servent bien de terre non ?
Parce que je parlais bien de relier les terres, pas les neutres et encore moins les neutres aux terres...
les écrans c'est zarb niveau électrique m'ais c'est comme ça. T'as déja regardé un écran ? T'aura sans doute remarqué une tresse métalique autour du tube (et je parle pas du degauss), cette tresse est le neutre (car on parle pas de masse en AC) et cette tresse touche le cadre et qques parties metaliques...
WiLL
Citation de: high_cobra le Mercredi 22 Août 2007, 13:56:36 PM
Ok, je ne savais pas ...
Mais alors où va la terre ? Elle s'arrête à l'alim de l'écran ?
En général elle s'arette à l'alim ou t'as plus que phase et neutre qui repartent vers l'écran. Je parle de mon expérience au niveau des bornes Euro et des moniteurs Hantarex en général, je sais pas comment ça se passe sur les machines à laver...
WiLL
Citation de: high_cobra le Mercredi 22 Août 2007, 15:03:06 PM
En général sur tous les produits dont la carcasse est métalique, la terre est relié à la carcasse ...
Si un fil de phase se dénuait et venait en contact avec la carcasse, tu y touches, tu es mort ... Alors que si elle est reliée à la terre, bah, ça disjonte, tout bêtement.
C'est pour ça que je pensait que le chassis des écrans était aussi à la masse.
Merci High_Cobra, je me coucherai moins bête ce soir ... bon ça c'est pas forcément difficile  :-\
morzana
#25
Salut
Citationj'ai remarqué que le Ground de la video etait a l'emplacement 28 du jamma au lieu du 14
As-tu recablé la masse vidéo à la broche 14
Citationune difference des tension: je m'explique entre la masse de l'ordinateur qui est de zero et la masse de la borne qui n'est pas tout a fait a zero, qui fait sauté le différentiel ? ?
Quand tu parles de la l'alimentation de la borne, j'imagine que tu parles de l'a limentation basse tension (+5v,+12V), or ces masses doivent être communes, il ne doit pas y'avoir de différence de pontentiel.
Verifie la continuite (ohmetre), borne éteinte pc relié que :
- Masses du Jamma (A,B,1,2,14,E,F,27,28) sont bien reliées entre elles
- Masse Alim basse tention -> Une des masses du Jamma
- Masse Alim PC -> Une des masses du Jamma
Je connais la norme d'isolement des appareils electrique mais on dirait que ce n'est pas d'actualité sur les écrans... C'est pour ça que je disais que je ne savait pas comment c'est sur les bornes jap plus récentes donc peut etre un peu plus "aux normes" question isolement...
je viens de regarder c'est tout pareil sur mon sanwa.
phase et neutre arrive au moniteur avec la tresse autour de l'écran
mais aucune trace de terre.  :-X
cela dit question norme, le chassis de l'écran n'est pas sensé être accessible par le commun des mortel mais par un technicien qualifié.
normalement l'écran est sensé être planqué derrière son carter an plastoque ou le bois de la borne...
sebastien
#28
 ;D bonjour
je pense que c'est normal puisque le tube cathodique fonctionne comme un condensateur un + la ou vous brancher l'anode de la tht et un moin les deux parties de gauche et droite du tube ,la tresse autour de l'ecran évite surtout de vous défriser les cheveux facon de parler y'a pas d'interet a mettre une terre sur un condensateur et pour le mettre ou  ;D.
deplus je pense que vous le constater quand vous decharger un tube cathodique avec deux tournevis de l'anode au partie qui sont noir ...
la terre n'est brancher que sur le bati métallique
as tu trouver ton defaut ?
WiLL
sebastien
Citation de: WiLL le Vendredi 07 Novembre 2008, 22:41:31 PM
On a un grand gagnant de déterrage de topic !  :-)= ;D
:D je suis d'accord  ;D , j'aurais bien aimer savoir si son problème était résolu  :P
Darius
salutation,
oui la borne marche depuis 1 ans,
réparer par un professionnel car je n'avait plus le gout de le faire moi meme.
Il a changer le transfo je crois .... si je retrouve les details je vous dirai ...
