MiSTer fpga - WIP divers
Démarré par funkycochise, Dimanche 08 Novembre 2020, 08:28:37 AM
CitationMain:
- CHD CD image support (Zakk)
- Send UART mode and speed to core.
- Fix menu hang on F12 autorepeat.
- Update logo in OSD.
- New config options for UART and Save States.
- arcade: support for load/save of NVRAM.
Citationao486:
- Support for MT32-pi over USER I/O port
- Add mpuctl utility to control MT32-pi
CitationHardware:
- Add MT32-pi interface board
CitationGameboy:
- Graphics, mappers and GB link fixes (paulb-nl)
- Save states (including FF/REW) (Robert Peip)
Citation
Main:
- Add MT32-pi settings for AtariST and Minimig cores.
- arcade: don't load nvram if not found.
- megacd: fix CD audio broken in previous release (zakk4223).
AtariST:
- Add support of MT32-pi
Note: you have to update Main as well!
Minimig:
https://misterfpga.org/viewtopic.php?t=147&p=15853#p15853
Citation
ao486:
- Reset i2s input samples (fix distorted audio).```
https://misterfpga.org/viewtopic.php?t=147&p=15854#p15854
Citation
ColecoVision:
- Option to hide border.
- Support for custom aspect ratio.
- Update the framework.
https://misterfpga.org/viewtopic.php?t=147&p=16020#p16020
Citation
Arcade ComputerSpace:
- Improve explosion sound (bellwood420).
- Other minor updates and tweaks.
https://misterfpga.org/viewtopic.php?t=147&p=16038#p16038
Citation
Aquarius:
- Support forced_scandoubler.
https://misterfpga.org/viewtopic.php?t=147&p=16040#p16040
Citation
Coco2:
- Support for real tape through the ADC adapter
- Support for forced_scandoubler
- support for custom aspect ratio
https://misterfpga.org/viewtopic.php?t=147&p=16048#p16048
Citation
Arduboy:
- Support forced_scandoubler INI option.
https://misterfpga.org/viewtopic.php?t=147&p=16072#p16072
Ca bouge souvent et on trouve vraiment de tout (même l'arduboy).
Va falloir que je m'équipe c'est sûr ! Je verrais bien ça avec ma petite lignée d'ordinosaure  :D
CitationNew core: Do Donpachi (Cave 68000) (nullobject)
I've taken the liberty to post this here in the official thread, in case people don't monitor the "Arcade" subforum.
CitationDonkey Kong, Radar Scope
- Upgraded Donkey Kong from MiST
- Includes Radar Scope
- Also Includes Pest Place and DK 3
CitationNES:
- Fixes for PPU and MMC3 (Kitrinx).
- Improved MMC1 mapper (paulb-nl).
- Fix zapper mouse trigger mode.
CitationNeoGeo:
Citation**CPS1/1.5 96MHz** version attached to Patreon post
pour ceux dont la sdram ne supporte pas le 48MHz (comme moi)
Citation1943, Vulgus and GunSmoke default orientation changed so the default setting for FLIP will be right.
Tiger Road ADPCM fixed.
Citation**Sound Accuracy Update** 20 cores affected.
https://www.patreon.com/posts/46260568
CitationAliceMC10:
- Added support for real tape through the ADC adapter (entree audio jack)
Citationao486, AtariST, Minimig:
- Use USER_IN[0] for MIDI RX.
CitationC64:
- Update palette to latest and more accurate colors.
- Use Win+F11 as original RESTORE when Action Replay or similar cart is used.
Citation
Would be nice if one could define a Win-Key substitute.
Because none of my mechanical keyboards has that key! (those keyboards are almost as old as i am
CitationAstrocade, BBCMicro, BK0011M:
CitationMinimig:
- Fix MIDI input over USER_IO port. Add note to readme.
CitationSNES:
- Fix bus A sources for CPU IO addresses (srg320).
- Justifier support for Lethal Enforcers (Shane Lynch).
- Lightgun: fix coordinate translation.
- Fix pixels artifacts on VGA output.
CitationC16:
- C1541: update VIA.
VIC20:
- Audio fixes (nino-porcino).
CitationZX Spectrum:
- Support for 48K SNA format.
- Some minor fixes and tweaks.
CitationMacPlus:
CitationMegaCD:
- Fixes (Timer, bus access) from srg320.
CitationAmstrad:
- CRTC: attempt to fix constantly re-triggered VSYNC in the same row (gyurco).
CitationGameboy:
- fix fastforward soundoption with FF-toggle mode (Robert Peip)
- add RTC internal functionality and saving to sdcard (append to savegame) (Robert Peip)
CitationAtariST:
- Update gstmcu to latest.
CitationCoCo2:
- Added "passthru" for cassette (based on PIA selection)
- Adjust brightness of inverted text
- Added Dpad emulation of analog stick
- Add capslock to function as upper/lowercase (shift-'0' on original machine)
- Add OSD selection for original keyboard layout (approximation)
- Improve menu settings arrangement
- integrate newest framework fixes
CitationMegaCD:
- Fix and rework auto-region.
CitationCentipede
Audio fixes and other fixes by JaguarLV
CitationMenu:
With great help from bellwood420 this build has workaround against DDR3 bridge hang. I think every user noticed time after time video got screwed (it's especially visible on HDMI. VGA users may just get some strange misbehave of core) so only hardware reset or power cycle could fix it. Probably this came to an end. This is an initial attempt to fix the issue, so currently in order to avoid video to get screwed you have to start cores from Menu core. Later, if this will be proven as fixed, the fix will be added to all other cores so it will be possible to start core from core without going back to Menu core.
So, i need feedback if this build fixes the problem. But you have to strictly follow following rules or fix won't work for you:
- Start any core ONLY from Menu core (...
CitationDonkey Kong 3
+ Released gaz68's Donkey Kong
+ the build seems a little unstable, but this RBF is good. Needs timing fixes.
CitationBBCMicro:
- Support for multires screens (Elite)
CitationFuture Spy, Zaxxon, Super Zaxxon
+ new game support - Future Spy
+ updated sys
CitationGameboy:
- Fix timer and some mappers (Robert Peip).
- Other fixes.
CitationJupiter:
Memtest:
- Add joystick support (misteraddons).
CitationMegaCD:
- Rollback Timer interrupt fix caused problems in several games.
- Don't filter audio from CD addon.
- Other fixes.
CitationVIC20:
- Fix audio distortion.
- Other fixes.
Un projet compagnon intéressant : le mt-32 pi, permettant le support du son general midi pour les jeux le supportant sur différentes plateformes.
Trois news intéressantes.
Déjà le projet mister a désormais son discord.
Discord mister
et ces jours-ci, Alan Steremberg a annoncé deux nouveaux chantiers :
- l'ajout du support persistant des hiscores façon hiscores.dat. dans mame.
- le support du flip screen sur les jeux dont l'orientation vertical est clockwise en anticlockwise quand l'option n'existe pas dans le disp switches. (au prix de quelques ms de lag).
Certains jeux avaient déjà cette option comme legendary wings
Car autant à un moment le "standard" adopté a été à un moment l'anticlockwise (comme pour les cave ou les toaplan), autant avant c'est un peu la foire à la saucisse.
Galaga, Frogger, Pacman, Galaga 3, Pacman,Pooyan et beaucoup d'autres sont clockwise.
C'est un travail de longue haleine et un français, wark91 s'est attelé à la tache en proposant un parser en python pour le hiscore.dat et les nvram des hiscores.
L'idée pourrait même aller plus loin en proposant un tableau des meilleurs scores en ligne.
galaxian et scramble ont été modifiés et fonctionnent
Super cool comme idée  ^-
On se retrouve avec une solution de remplacement matériel avec des ajouts de fonctionnalités.
On peut imaginer pleins de possibilités futures au vu de l'engouement pour le développement de ce matériel.
ça cherche des connaisseurs en php pour intégrer le tableau des scores sur le site officiel.
8)
Un chantier intéressant vient de s'ouvrir (un de plus  :D )
Il s'agit de l'upscale x5 coupé en 1080p avec décalage paramétrable de l'overscan.
https://www.retrorgb.com/mister-1080p-5x-beta-testing.html
x4 vs x5
et une fois l'image decalée, la porte est visible entièrement :
ça ne conviendra pas forcément à tout le monde mais c'est une option intéressante.
j'ai testé les cores suivants avec cette option : SNES, NES, MD, PCE, NeoGeo, SMS
Le core Gameboy a été mis à jour par fpgaZumSpass.
Il inclut désormais les options de Rewind, De Fast Forward et de Save State.
Jotego, à l'origine de beaucoup de core arcade a mis à jour la puce Yamaha 2151 pour une précision accrue du LFO et de la voix Noise. Beaucoup de core ont été mis à jour.
D'ailleurs sa reproduction est aussi désormais utilisé pour une puce de remplacement.
fpgaZumSpass a annoncé ses travaux sur un coeur lynx.
srg320 a commencé le développement d'un coeur saturn
et playstation qui arrive (par laxer3a, un français)
Ridge racer
Une nouvelle version du core Atari 7800 est disponible avant release officiel.
Il corrige tout les glitches qui était visible auparavant.
C'est Rysha qui s'y est collée et a pratiquement fait le cœur toute seule.
Petite video sur l'émulation midi mt-32 intégrée au Mister
c'est intéressant, mais il faut aimer (ce n'est pas mon cas)
et aimer les jeux PC (ce n'est pas mon cas non plus).
Les donkey Kong ont été modifié pour ajouter l'option de flipscreen
Le Jr arrive
