Arcade VGA 9200 + AdvMAme ou AdvMenu = Probleme
Démarré par Youki, Dimanche 13 Février 2005, 09:07:17 AM
Youki
Par hazard sur un forum U.S , j'ai lu que l'arcadeVGA 9200 fonctionne mal avec AdvMAME & CO.  Du a un probleme de drivers SVGALIB DOS et linux qui ne supporte pas les cartes recentes .
Enfin comme dit le gas, si vous avez une ArcadeVGA pas besoin d'utiliser AdvanceMAME.
voici le post en anglais :
> Hi,
> I set up and upright cab a while ago, and everything works really well. I used the
> following:-
> MSDOS
> ArcadeVGA card (7000)
> J-Pac
> ArcadeOS 2.52
> AdvanceMAME (latest build)
> When a mate wanted to build a cocktail cab I suggested he use the same components as
> me, so he ordered all the gear and we built it. However, the ArcadeVGA 9200 card has
> problems displaying certain programs - when they're run the J-Pac loses sync and the
> image turns to garbage.
> The text-mode AdvanceMAME configuration programs (advv, advcfg etc) and ArcadeOS are
> affected, although AdvanceMAME itself runs perfectly using the modes I've configured
> on my upright.
> We figured probably the quickest fix would be to change to another menu, and tried
> AdvanceMenu, but this does exactly the same thing. I've also tried tweaking the modes
> in the advmame.rc file, but no joy.
> We know it's not the monitor, wiring etc, since if I swap the 9200 for my older
> ArcadeVGA 7000 everything works fine.
> I'd be very grateful for any advice or info that anyone has on this problem. I've
> searched these forums and I've seen a couple of posts stating there are differences,
> but no real specifics.
> Cheers,
> Deano
This is stolen from the advancemame mail list archive.
Some users reported problem using the SVGALIB drivers with recent Radeon
boards, so I removed them
from the list of supported cards. Probably they never worked.
For Linux you can use the FrameBuffer drivers, they work. For DOS you
must use another video board.
They don't support the newer chipset radeon cards with advancemame.
If you are running this thru a jpac, and a avga card, why not just use regular mame?
Advancemame is only needed when you want 15k out of a standard card.
(I've got one cab with a t64 card and advancemenu and advmame that looks great. Dos 7, 256 meg ram, vertical monitor, with a jpac)
Youk
Je fait remonter ce post car je vais recevoir demain mon ArcadeVga et je commence à recup des infos pour installer Advancemame.
Mais aprés ce post ,j'ai des doutes. Est ce que finalement c'est utile d'utiliser Advancemame sachant que je tourne sous Xp avec ArcadeVga et JPAC ?
j'ai pas du bien comprendre l'utilté d'advance mame. Pour ce que j'ai compris , il est utile pour n'importe quelle configurations pour retrouver les résos d'origines. Mais en reflechissant, un des avantages de l'arcadevga est de trouver toute seule ces résos la.
Mais est ce qu'on parle bien de la meme chose ? Est ce que ça s'utilise avec le mame normal ?
bref , je suis paumé la ... :evil:
Lerklio
bah pas de raison d'etre paumé, ta question comprend la réponse,
si t'as une arcadevga, advmame ne sert a rien ;)
Bon je me suis mal exprimé  :P
en fait je voulais une confirmation de ce fait  :smile:
Anonymous
J'ai une arcadeVGA et sous windows j'utilise tout de même advmame carsous la version de mame standard , la res selectionnee n'est pas toujorus ideale pour certains jeux, et je trouve très pratique de pouvoir changer soi même le mode video ingame, une fois l'emulateur lancé (ainsi pas besoin d'aller toucher aux fichiers de config, tout peut être fait via le panel)
Cependant depuis que j'ai upgradé ma borne, version advame 0.63 à 0.95, la selection auto des modes videos curieusement n'est plus bonne.
Ainsi en lançant silkworm par exemple, il me le lance en 512 x 448 malgré que j'ai fixé le mode auto et "display_adjust x".
Quelqu'un aurait une idée poru résoudre mon problème ?
Youki
Citationla version de mame standard , la res selectionnee n'est pas toujorus ideale pour certains jeux
Il faut que tu utilise un petit utilitaire AVRES  qui te genere automatiquement les .INI qu'il faut pour tout les jeux pour l'ArcadeVGA.    Comme ca tu auras les bonnes resolutions.
Pour ton autre PB, aucune idee, je n'utilise pas Advmane.
Anonymous
Merci mais en fait j'avais dejà utilisé cet utilitaire et je n'étais pas pleinement satisfait. Pour certains jeux, le mode vidéo sélectionné n'était pas idéal. Je viens d'essayer Mame Res Tool, mais sans succès j'ai un msg d'erreur lorsque je veux générer la liste pour mame 0.95 ou 0.96 :(
