Réparation Driveboard SEGA Model 3 - Tuto & Repair Logs
Démarré par Tibal, Lundi 25 Septembre 2023, 22:43:21 PM
Tibal
I don't know really. I've never dug in that direction.
If you want to replace the optocouplers, type TLP521 on Aliexpress, you'll find them.
You can either take 4x TLP521-1, or 2x TLP521-2 or 1x TLP521-4 to replace 4 optocouplers. Sega populated differently from one Driveboard to the other as you can see:
areni2002
Thanks. I thought I might be able to use some of the resources I have. I've already ordered the new TLP521-1.
Sillicon
When I repaired several drive boards for a friend in February (see below) ;-), one behaved similarly.
If IC28 is working as you write, then check the activity IC28 on pins 1 and 19, if it is not there,
then if I remember correctly, the cause is IC18 or then IC2 and IC5.
I have repaired many of these boards and there has never been a faulty optocouplers or output drivers TD62384 and ADC M62353.
Note, the optocouplers inputs are powered from the CN1 and CN3 connectors.
areni2002
Hello after a long break. I finally managed to get this unfortunate board working. Although IC2, IC5, and IC18 were fine on the tester, I replaced them with brand new ones. The feedback loop started working, albeit with minor issues. After a while, an Err 24 error was displayed. Another board in the same machine worked fine. After a quick inspection, I fixed one solder joint and tested it in a different machine. It's working so far, so I'll keep testing. Thank you all for your help. In total, I've now brought six boards to life 😃
Tibal
That's great! Thanks for the report! ^-
While I'm at it, if you @areni2002 , @Sillicon or anyone have spotted chips that may be responsible for an Error 03, I would love to know :)
areni2002
I've never seen error 03. However, on my ER 24 board, it reappeared 😥. This happens after the game has been running for a while. I'd also appreciate any suggestions.
Romano
areni2002
Hello. Repairs to the 7-segment display boards are going quite well, although one is resisting ;) However, I have several servo boards from various machines (Scud Race, Sega Rally 2, Club Kart - MIDI) that aren't working. Has anyone had any success repairing them? The MOSFETs seem fine to me. I've also checked the diodes and various passive components. I'd appreciate any suggestions.
