Réparation Driveboard SEGA Model 3 - Tuto & Repair Logs
Démarré par Tibal, Lundi 25 Septembre 2023, 22:43:21 PM
areni2002
#96
Hi, I'm trying to fix the driver board. Thanks to the advice from this forum, I've managed to run 3. But I have a problem with one. Everything seems to be fine, but it doesn't work in the game. It doesn't show a drive board error, but ffb doesn't work and it's running at er 20. Any ideas what to do now? I can't upload video file to show you.
Hi,
I know nothing about the driveboards, so I won't be able to help you ;).
Citation de: areni2002 le Dimanche 06 Juillet 2025, 15:05:07 PMbut ffb doesn't work and it's running at er 20.
What do you mean ? Could you say it differently because I don't understand what "at er 20" means ?
Citation de: areni2002 le Dimanche 06 Juillet 2025, 15:05:07 PMI can't upload video file to show you.
You cannot upload video directly on Gamoover. You need to create a Youtube account, upload it on Youtube, and then share it with us this way :
[youtube]561H-MtscjA[/youtube]
"561H-MtscjA" being the code of your Youtube video :).
areni2002
Tibal
#100
Is it performing the initialisation when plugged in the cab, at power up?
Can you make a video of it to see the wheel movements and the 7 segment display?
All I can say from your video for now is that you're NOT in case 0-1-2-3 of the tutorial
areni2002
I'll make a video at the next opportunity. I noticed that the 7-segment displays don't light up at the same time. You can see it in the video. I've already checked all the elements from the guide and OKI. The ones on the back of the board are left.
areni2002
After connecting the Drive Board to the game, it behaves the same as before. For comparison, here's a second video showing a working Driver Board. I'm testing it in Sega Rally 2 with the correct ROM, as Scud Race has other issues.
areni2002
The steering wheel doesn't turn and there's no Driveboard Error message on the screen. There's no need to record a video. The game starts normally, just without FFB. The 74HC chips from step 5 have been replaced with new ones. Any other ideas?
Tibal
#105
Ok, then maybe check the diodes close to the connectors
Edit: you can also unplug 1 connector at a time and test with the working Driveboard to see if you can reproduce this behaviour.
areni2002
#106
The diodes have already been checked. I'll test the connectors when I have the opportunity
Tibal
#107
I don't really know.
I guess finding which connection(s) needs to be cut to lose initialisation + no Driveboard error will narrow your research.
Optocouplers?
areni2002
The optocouplers also seem fine to me. Maybe the TD62384AP chips? I ordered new ones and the M6253 converter on AliExpress.
areni2002
Disconnecting CN3 had the same effect. I checked the optocouplers again and desoldered and checked IC28 – it's working. I'm still waiting for the new OKI and TD chips.
areni2002
I think the optocouplers are faulty. I tested them like the diodes, but everything was fine. I was surprised to find that on the diode side, without the connector connected, there was a voltage of about 2V. The meter showed over 200k ohms between the diode and the transistor. This only applies to the optocouplers behind the CN3 connector. Let me know what you think. While I don't have the parts, can this optocoupler be replaced with another one?
