Triforce type 3 netboot
Démarré par juju49, Dimanche 06 Avril 2014, 10:08:51 AM
aje_fr
De mémoire il y a plusieurs endroits à modifier, sur la carte mère et aussi sur la carte réseau.
Au pire j'ai aussi une type 3 donc si tu veux venir faire un test, pas de soucis.
A plus
juju49
Citation de: aje_fr le Mercredi 09 Avril 2014, 07:12:14 AM
A plus
Pourquoi pas , par contre je veux bien que tu fasse une tof' de ta carte avec les jumpers , ou un lien qui indique la marche à suivre si tu as ça  :D
Il y a des infos à ce sujet dans les commentaires du fichier python.
Citation
# connect to the Triforce. Port is tcp/10703.
# note that this port is only open on
#   - all Type-3 triforces,
#   - pre-type3 triforces jumpered to satellite mode.
# - it *should* work on naomi and chihiro, but due to lack of hardware, i didn't try.
Citation
# ok, now you're on your own, the tools are there.
# We see the DIMM space as it's seen by the dimm-board (i.e. as on the disc).
# It will be transparently decrypted when accessed from Host, unless a
# zero-key has been set. We do this before uploading something, so we don't
# have to bother with the inserted key chip. Still, some key chip must be
# present.
# You need to configure the triforce to boot in "satellite mode",
# which can be done using the dipswitches on the board (type-3) or jumpers
# (VxWorks-style).
# The dipswitch for type-3 must be in the following position:
#   - SW1: ON ON *
#   - It shouldn't wait for a GDROM anymore, but display error 31.
# For the VxWorks-Style:
#   - Locate JP1..JP3 on the upper board in the DIMM board. They are near
#      the GDROM-connector.
#      The jumpers must be in this position for satellite mode:
#      1      3
#      [. .].   JP1
#      [. .].   JP2
#       .[. .] JP3
#   - when you switch on the triforce, it should say "waiting for network..."
# Good Luck. Warez are evil.
juju49
Justement:
"The dipswitch for type-3 must be in the following position:
#   - SW1: ON ON * "
ça dit bien de mettre le dip 2 sur On pour les T3 , et bouger les jumpers pour les T1  ;)
Tormak
De ce que j'ai compris tu dois :
-Mettre sur ON les 2 premier dipswitch du SW1
-Régler les jumpers proche de connecteur GDROM comme sur le schéma :
JP1 sur les 2 premières broches
JP2 Idem
JP3 sur les deux dernières, ce qui donne :
Voilà qui d'après la doc, ce que tu dois faire sur la CM.
juju49
Bon après multiples recherches sur le net, il semble obligatoire d'avoir un PIC "zero" ou un truc du genre  :-\
Sur les triforce type 3 , il faut simplement modifier le DIp 2 sur On , il n'y a pas de jumpers à modifier.
Une idée de ce qu'est un PIC "zero"
Merci  ^-
Citation de: juju49 le Samedi 12 Avril 2014, 15:57:46 PM
Merci  ^-
oui c'est un security chip avec une clef d'encryptage à zero (aka netboot).
