[BOARD] Sega FFB Controler (MULTI) et Sega FFB Controler Pro (JVS)
Démarré par Aganyte, Vendredi 31 Janvier 2020, 09:24:55 AM
Homarj
Thanks for the response, I have played with the power law and still can feel the vibration.
I am unable to unselect the quater pulse as it says not available on all hardware.
In terms of installing the capacitor, sorry I have limited knowledge with electronics so trying to understand where this is installed. Is it between steering wire in betweeen M3 hack and FFB controller and is that linked to the ground or just inline on the wire?
Thanks.
Tibal
Do you have the grounding bridge on your Midi board ? Can you send a picture of it ?
For the capacitor, the negative leg has to be connected to GND, and the positive one to the wheel signal (analog 0 I guess ?).
Send pictures of your setup and we will see where it's easy to solder
Homarj
Attached are the pictures inside my machine. The midi board is bridged from what I understand. Thanks for the assistance.
Tibal
Yes, you have de GND bridge.
This is a zoom of your picture.
You can put the capacitor here on your m3hack. To test the value, no need to solder it, just hold it there with the positive leg on STEER and negative leg on GND and see if the steering gauge stands still on BFF. If it still moves, take a higher value. If it's ok, solder it and test in game
Homarj
Sorry for the slow response had a few mistakes along the way firstly with getting 475uf instead of 0.47uf and then i messed up my soldering and lost all control. Anyway all sorted now and it has definetly helped and smoothed it out, I think some minor tweaks still needed but much better. Appreciate the assistance. Thanks.
Hakkyokuken
I am interested in purchasing a kit for my initial D 1 twin cabinet. I will primarily be using PC, but Naomi/Lindbergh/ringedge are also options.
Thank you!
Mrhide
Citation de: Mrhide le Dimanche 01 Août 2021, 18:07:08 PMdonc quoi, ce graphique qui dit 5v -> 24v n'est pas bon?  ( https://hico-srv022.pixhotel.fr/sites/default/files/gamoovernet/20210327090257-gojirien-PC2FFB-PWM2M2-Wiring-Diagram.png )
2 ans plus tard, je vois avec plaisir qu'il y a maintenant un warning:
Merci ;) ... je viens d'ajouter une Sega Race TV (Lindbergh) à mon arsenal:
...et rapidement, je me retrouve ici à vouloir peut-être reprendre le projet.  je dois être maso :D
SDF
Salut @Aganyte,
Apres près d'un an sans mettre la main sur ma racecab, je la remet en service et je scrute donc ce topic. J'ai une conf un peu bizare, c'est une base de le mans, avec un panel de SR1, sans les driveboards. J'avais déjà acheté un PWM2M2, mais je me retrouve avec le volant qui part tout le temps vers la droite dès que j'active le drivers Vjoy. rien n'y fait. j'ai beau envoyer des commandes (sur serial monitor de l'IDE arduino) à gauche, mais c'est toujours la droite qui est enclenchée.  Je vois également qu'il faut dorénavant cette carte Sega FFB ??? Bref je ne comprends plus rien et j'aimerais bien quelques infos pour remettre tout ca en ordre stp.
Merci.
Il faut que tu me décrives toute ton installation. Attention aussi avec le pwm2m2, si ça fait longtemps que tu l'as, il n'a peut être pas le bon firmware.
SDF
#649
Citation de: Aganyte le Mercredi 12 Juillet 2023, 13:11:02 PMIl faut que tu me décrives toute ton installation. Attention aussi avec le pwm2m2, si ça fait longtemps que tu l'as, il n'a peut être pas le bon firmware.
Ca doit faire un bon moment, ceux que je vois passer sur les photos sont pas pareils, je dois avoir une des premières versions.
Mon install (je me consacre qu'a la partie volant, le reste on verra plus tard) :
- Panel SR1
- PWM2M2
- Arduino Leonardo (maintenant c'est un mega qu'il faut il me semble)
- Transfo 32V + Convertisseur tension 32V->24V (je vois plus haut qu'il faut pas dépasser 17V ???)
- Transfo 110V (d'origine)
Merci Christophe ;)
Tu peux effectivement remplacer le leonardo par un Arduino Mega ou un "FFB controller hack" et tu vas devoir m'envoyer le Pwm2m2 pour mise à jour
SDF
#651
Citation de: Aganyte le Jeudi 13 Juillet 2023, 09:14:38 AMTu peux effectivement remplacer le leonardo par un Arduino Mega ou un "FFB controller hack" et tu vas devoir m'envoyer le Pwm2m2 pour mise à jour
C'est une obligation ? Ca peux pas tourner avec un leo ? Je dois en avoir un qui traine mais ca m'oblige à revoir tout le câblage (ptet pas un mal non plus).
J'utilise quel schéma et quel programme (du mega) du coup ?
File moi ton adresse en MP stp pour le renvoi du PWM2M2.
SDF
#653
Citation de: Aganyte le Jeudi 13 Juillet 2023, 10:25:44 AMPour le leonardo, je te laisse voir ça avec Njz3.
Je trouve pas les infos comment brancher l'arduino mega sans carte sega ffb. J'ai bien compris que les commandes supp sont branchées sur le mega en direct (bornes 46 à 53) mais quid des potards de wheel/acc/brake et des autres boutons (view2/start/...) ?
Edit : C'est bon, j'ai trouvé sur son github.
Tu la fait à combien ta carte ffb ?
Merci poulet.
simulate
Hello
My computer is not working properly. I have to update the device and reinstall Windows. An exception occurred during installation.
error message
Unable to load dll 'lua54' The specified module could not be found.
How to solve this problem? Thanks
Own Vewlix initial D
njz3
Dont worry, that is just a missing dll for an internal scripting plugin, that is not used anyway.
