Problem with L2M2
Démarré par Akiles, Samedi 09 Février 2013, 21:26:46 PM
Akiles
#16
Solved
One more thing rods marked with a red circle Where I can I get them?
I think the right résistor is correct : 1,2kohms brown,red,red,gold
But the left one seem incorrect : you must have 180ohms brown grey brown gold
they are spacer that you can find in electronic webstore
http://www.gotronic.fr/cat-entretoises-hexagonales-f-f-734.htm
Akiles
#18
Iro the spacers you have used are of 40mm of height?
The two blue resistors of the left are differents to you.
Can you keep those resistors or have I to change with two of 180 ohmios necessarily?
I don´t know why RetroRepair has put those resistors instead of you.
20mm for the spacers
I think you should change the left resistors because their values are much different than that is needed
Akiles
Akiles
#21
solved
No, maybe a professional but i guess the price of the job will the same as new wheel ....
Or you can cover it with leather
http://www.boutiquedutapissier.fr/couvre-volant-cuir.html
Akiles
Akiles
#24
Solved
I have uploaded this image in high rsolution to you see the position of those resistors.
Have I to change of position those four resistors to work fine haven´t I?
resistors have not + or -, you can weld them in any direction.
So check all your resistors with the tutorial and change them if needed
http://www.gamoover.net/tuto/l2m2-interfacer-un-ffb-et-volant-sega-model-12-avec-un-pc-ou-une-playstation-23
Akiles
#26
Then Iro if the resistors have not + or - I can let them without change of position.
yes if my memory is still correct :)
Akiles
Akiles
#29
Hi Iro if the voltage measurement is less than that indicated in the RV, I must move to regulate the potentiometer screws marked with a black circle.Is it correct:
One more thing the wires length influence in the force of steering wheel.
All wires to the motherboard L2M2 must be as short as possible to avoid a loss of strength in the steering wheel motor.Is it correct?
I say this because I have the transformer in the bottom of the cabinet.
So you would have to put two long wires from the power transformer to the plate L2M2.
Iro can you say me where do you have the transformer,near the steering wheel or the bottom of the cabinet like me?
Citation de: Akiles le Jeudi 21 Février 2013, 10:37:36 AM
Yes.
This is what I found.
The transformer is under the pedals.
You can see it on this photo
The L2m2 is behind the steering wheel under the screen
Akiles
#31
Fixed.
