Auteur Sujet: [Beta] - BackForceFeeder : feeder vJoy FFB pour racecabs  (Lu 50411 fois)
Hors ligne Little_Rabbit
  • ✌(◕‿◕)✌ Donateur 2022
  • Staff
  • Dieu de l' Arcade
« Réponse #608 le: Mardi 15 Juin 2021, 15:17:16 pm »
  • Salut,
    @madein80 et njz3 : j'ai déporté vos échanges vers ce nouveau sujet ;).
    Ma gaming room
    Hors ligne njz3
    • Grand Pilier
    « Réponse #609 le: Mardi 15 Juin 2021, 15:23:33 pm »
  • @Little_Rabbit: Merci pour le nettoyage.
    Hors ligne leestow
    • Intéressé
    « Réponse #610 le: Mercredi 07 Juillet 2021, 18:37:28 pm »
  • Is it possible to connect a bts7960 driver to the mega2560?  If so, what is the pinout please.  Any help would be appreciated.  I would like to use the mega 2560 so I can use lamps with the uln2003
    Hors ligne njz3
    • Grand Pilier
    « Réponse #611 le: Jeudi 08 Juillet 2021, 11:07:36 am »
  • @leestow: the current Arduino code does not support the Mega2560 with fast PWM, only standard PWM@960Hz which means you will probably hear some noise. I did not spend too much time to support analog PWMs based control on the Mega2560, so it is not yet ready to work out of the box.
    Current code for the Leonardo does support L620X based motor driver with 15,9kHz PWM (noise barely hearable), so something can definitly be done to support the BTS7960 module. Depeding on the number of buttons and lamps, and adapting slightly the arduino code for the Leonardo can maybe fit your needs.
    Do you have the pinout for your module and a Leonardo to do some testing with current code ?
    Hors ligne leestow
    • Intéressé
    « Réponse #612 le: Vendredi 09 Juillet 2021, 04:39:19 am »
  • @njz3. Yes.  I have a Leonardo and the bts7960 module.  It has vcc, gnd, r_is, l_is, r_en, l_en, rpwn, lpwm pinouts.
    Hors ligne njz3
    • Grand Pilier
    « Réponse #613 le: Lundi 12 Juillet 2021, 14:27:03 pm »
  • I have to check for the wiring, normally it should be compatible with the current Arduino code very easily as I support dual PWM outputs for reverse/forward mode (BTS7960 and L620X both share the same dual PWM inputs logic).
    How many buttons, pedals and lamps do you have on your setup?
    It might be possible to connect them all on a Leonardo, which would definitly be better for the noise at this stage since I did not look how to increase pwm frequency on the Mega2560.
    Hors ligne leestow
    • Intéressé
    « Réponse #614 le: Mardi 13 Juillet 2021, 03:48:25 am »
  • 10 buttons including the 4 speed shifter.  And 6 lamps.  It's a San Francisco Rush 2049 cabinet.
    Edit:. I forgot.  It also has 3 pedals.
    « Modifié: Mardi 13 Juillet 2021, 07:31:33 am par leestow »
    Hors ligne njz3
    • Grand Pilier
    « Réponse #615 le: Mardi 13 Juillet 2021, 13:52:00 pm »
  • Ok, then the Leonardo will not allow as many buttons and lamps to be controlled.
    Anyway, let's try the Leonardo for at least the motor control, pedals and buttons (no lamps yet).
    For the wiring, you shall do the following:
    - connect L_pwm pin to D9 (Forward)
    - connect R_pwm pin to D10 (Reverse)
    - connect L/R EN(able) pins to D11
    - connect your wheel pot to A0, your pedals to A1 through A3
    - connect your buttons to D0 to D8 and D12 (10 buttons)
    If you can, please try with a lab power supply where you can set a current limit to something like 1 or 2 amps to avoid burning your BTS7960.
    Do not switch on your power supply yet.
    In the BFF (latest 0.5 version), use PWM_DIR hardware. Stop the manager and tick the "Dual mode PWM (L620X)" checkbox. Restart the manager and click on "Commit eeprom&reset". Please see below where those options are:
    Calibrate your motor first, then your wheel axis (same procedure) and your pedals axes, then check your buttons are detected in the buttons page.
    Then enable your power supply with limited current, and use the Diagnostic mode to check if motor control works.
    Hopefully it will work with no modification in the Arduino code.
    Edit: corrected a few typos and mistakes in my message
    « Modifié: Mardi 13 Juillet 2021, 14:07:27 pm par njz3 »
    Hors ligne nonosto
    • Addict
    « Réponse #616 le: Mardi 13 Juillet 2021, 15:40:13 pm »
  • C'est vraiment le top, quel sont les driver utilisé pour les PC, y a moyens pour XBOX 360 (Daytona USA...) Merci
    Hors ligne njz3
    • Grand Pilier
    « Réponse #617 le: Mardi 13 Juillet 2021, 16:36:44 pm »
  • Le driver Windows est vJoy (c'est un joystick virtuel), ce n'est pas compatible avec une xbox 360.
    Sauf peut être avec un Gimx mais je ne peux pas encore aider là dessus.
    Hors ligne bandicoot
    • Famille
    « Réponse #618 le: Mardi 13 Juillet 2021, 21:41:39 pm »
  • pas d'Xbox avec GIMX
    Mon pincab
    http://www.gamoover.net/Forums/index.php?topic=23174.0
    Hors ligne nonosto
    • Addict
    « Réponse #619 le: Mercredi 14 Juillet 2021, 09:27:02 am »
    Merci beaucoup pour le travail colossal, je sait que j'abuse un peu mais est il concevable d'utiliser les driver 360, car la version daytona USA xbox 360 est la meilleur ever.
    Hors ligne njz3
    • Grand Pilier
    « Réponse #620 le: Mercredi 14 Juillet 2021, 22:34:43 pm »
  • Merci beaucoup pour le travail colossal, je sait que j'abuse un peu mais est il concevable d'utiliser les driver 360, car la version daytona USA xbox 360 est la meilleur ever.
    Malheureusement si le gimx ne fait pas, je ne connais pas d'autres moyens.
    Faut voir si un emulateur xbox 360 sait un jour faire tourner Daytona avec support pour vjoy.
    En attendant tu as quand même la version arcade sur emulateur model2 qui tourne parfaitement avec le FFB.
    Hors ligne leestow
    • Intéressé
    « Réponse #621 le: Vendredi 16 Juillet 2021, 05:06:24 am »
  • Would it be possible to add another Arduino to just control the lamps?
    Hors ligne njz3
    • Grand Pilier
    « Réponse #622 le: Vendredi 16 Juillet 2021, 08:40:28 am »
  • It is technically possible, but not yet planned as it would make the software a lot more complicated since there would be dual serial port communication and synchronization, and make the overall process a lot more CPU hungry.
    The simplest solution I was working on, would be to add an I2c chip to extend the IOs of the Leonardo with 8 or 16 more digital IOs. In your case, another solution would also be to configure higher frequency PWM for the Mega2560.
    Please test first the Leonardo and give me your feedback.
    Hors ligne leestow
    • Intéressé
    « Réponse #623 le: Samedi 17 Juillet 2021, 15:36:23 pm »
  • Okay.  Thanks for your help!  I'll test it out as soon as I get some extra time.  Also, have you thought about using a raspberry pi?  Maybe to offload the the CPU processing to the pi?  Plus a lot of gpio pins.  I'm no expert.  Just curious.
