Un projet sympa : Naomi Pi
Démarré par th_vador, Jeudi 27 Juin 2013, 22:07:08 PM
ian57
Citation de: Nekoma le Mardi 31 Mai 2016, 17:49:51 PM
je l'ai mis là:
http://www.partage-facile.com/VJOEJJG2RB/naomi.7z.html
Yop t'as moyen de flasher toi? moi je n'ai pas trouvé de programmateur d'eprom à mon taf...
j'ai pas trop envie de mettre 30€ pour un 1 shot ;)
Merci pour le lien
Citation de: ian57 le Mardi 31 Mai 2016, 19:21:22 PM
Merci pour le lien
je peux te fournir une eeproms avec le cablage nekoma au besoin ;)
ian57
Yop, je viens de tomber sur un des fork de piforcetools https://github.com/amosso75/piforcetools/commit/254dbd1c1b186e7c1fda404632b4cb5382208de2
celui ci à l'air bien... je vais le tester et le modifier pour la gestion des leds et shutdown
adding features
- Sorts games by arcade system (Naomi 1, Naomi 2, Chihiro, Triforce) ;
- Sorts games by genre (Fighting, Horizontal Shmup, Puzzle, ...) ;
- Enables you to go to the previous/next letter inside any game list ;
- Multi-language support (for now only French & English) ;
- Enables you to give a nickname to each IP address for easy reading
(useful when you have a multi-system setup) ;
- Enables you to define for each arcade system which IP addresses you
allow as a target for uploading. The first IP of this list is the
default one with fast access to upload a game ;
- Enables you to customize the items you want in the main menu and
their order of appearance ;
- Enables you to customize the items you want in the "Games by genre"
and "Games by system" menus and their order of appearance ;
- Easy configuration of inputs (default one is the one I use but I
wrote another one in comments just as an example) ;
- Inputs management recognizes a long button press ;
- Shows a list of the "non matching" .bin files in the roms folder and
enables you to choose an "orphan" game for automatic .bin file renaming
- Enables you inside any game list to add or remove a favorite game
(this list is saved in a text file) ;
- A little heart is placed next to a favorite game's name on any list
- Shows a list of your favorite games ;
voila voila
ian57
le boitier est terminé. Il est spécialement conçu pour un Pi1 revB 512 et le module LDC de chez banggood ou Deal extreme http://www.banggood.com/Negative-16-x-2-LCD-Keypad-Kit-RGB-Backlit-For-Raspberry-Pi-p-960166.html
Je vais mettre les STL sur thingiverse...
ian57
Citation de: Iro le Jeudi 02 Juin 2016, 11:49:44 AM
trés sympa !!
Merci ... j'ai un peu galéré pour mettre les trous en faces des boutons du module LCD.
Gnomon
ian57
#215
Voila c'est en ligne : http://www.thingiverse.com/thing:1603284
la suite... la modif du code source pour intégrer les fonctionnalités de amosso75.
dominion
Bon les gars, j'ai lâché l'arcade depuis 4-5ans environ pour cause de 2 mouflets  :D
Le premier commençant à être en âge de jouer, je vais m'y remettre.
Vous m'avez fait envie là !
J'en étais resté aux jeux netbootables via PC, moi je le faisais depuis mon NAS.
Je sens que je vais trouver une bonne utilité à mon raspberry  ^-^
ian57
#217
j'ai donc bidouillé la version des piforcetools d'Amosso75 : https://github.com/ian57/piforcetools-1.X pour l'écran DX ou banggood
j'ai ajouté en plus de son super taf, la gestion de la led RGB(vert = ok, Bleu = working, Red=Problem), une tempo qui permet d'éteindre l'écran au bout de 15s et l'appui sur une des touches le rallume, l'ajout du menu Shutdown pour un arrêt propre du Raspi.
Un appui court sur select = enter
Un appui long sur select = Echap
les autres touches réalisent les déplacement dans le 4 directions.
Les menus peuvent être mis en français ou en anglais (pour l'instant)
en video :
English
Français
Solkan
petite question : comment tu developpes et débugges le python ? Utilises-tu un émulateur, une IDE spécifique ou directement sur le Raspberry ?
Solkan
ian57
Citation de: Solkan le Mardi 07 Juin 2016, 08:22:46 AM
ben la directement sur le pi en ssh depuis une machine de bureau avec Vim, car il faut l'accès au module lcd pour l'affichage et la LED, idem pour la carte SD et les fichiers de roms.. et puis c'est plus de la modif que du devel... du coup ça peut aller.
c'est sur pour un projet plus gros, il faudrait faire autrement, style tout faire sans l'accès au matos et ensuite ajouter sur le pi les trucs spécifiques au matos.
Solkan
Merci pour l'info, je m'en doutais. En fait, j'ai utilisé l'image (http://downloads.capane.us/piforcetools.img.zip) et je n'ai pas l'accès root.
Bon, je vais me faire un raspbian from scratch, ce sera plus facile.
Solkan
ian57
Citation de: Solkan le Mardi 07 Juin 2016, 08:33:45 AM
yep j'au aussi utilisé celle ci... et je n'ai pas trouvé le mdp root!, ni pi!! Du coup pour avoir l'accès, il faut mettre ta SD dans un lecteur de carte SD et monter sur un linux ou Mac (windows ne voit pas les partoches ext). puis tu édites le fichier /etc/passwd
root:x:0:0:root:/root:/bin/bash
pi:x:1000:1000:pi:/home/pi:/bin/bash
tu supprimes le x (correspondant au shadow passwd), tu enregistres et hop dans le pi. tu devras passer admin sur la machine avec laquelle tu fais les manips
root::0:0:root:/root:/bin/bash
pi::1000:1000:pi:/home/pi:/bin/bash
tu bootes et plus de mot de passe sur le compte root et pi (s'il existe)
ensuite tu remets tes mdp perso avec la commande passwd et passwd pi (pour le compte pi)
Sinon, dès que j'aurai testé en vrai avec la naomi (j'attends mon BIOS)  je vais mettre en ligne une image de ma sd sans les roms ;)
Pareil avec cette image, moi j'ai mis les roms sur la partoche EXT car j'ai eu des soucis pour étendre la partoche FAT32 dans laquelle les roms sont stockées par défaut
Aussi sur cette image, la partoche ext est en lecture seul pour éviter les soucis lors de l'arrêt violent (ben oui c'et pourquoi j'ai rajouté le menu shutdown), du coup pour faire les modifs sur la SD en ssh, il faut repasser en RW, ya une commande prévue ;)
sudo rpi-rw
voila voila
Gakman
Je viens de tester, ça ne marche pas. Mais en même temps c'est difficile de conclure, la version d'amosso n'a jamais marché chez moi. Le PiForceTools d'origine marche mais dès que je modifie ça ne fonctionne plus, j'ai peut-être un soucis avec ma SD.
ian57
Quel écran? Mes scripts sont fait pour l ecran banggood et les Roms sont dans home/pi
