[Topic Unique] RGB-PI: l'Émulation Console et Arcade facile et pas cher
Démarré par MicMey, Lundi 04 Janvier 2021, 07:29:05 AM
MicMey
Voici les nouveautés et les corrections apportées sur la nouvelle mise a jour de l'OS4 "(Alpha 13 20220724)" pour Raspberry Pi4/Pi400 uniquement.
RGB-Pi OS 4 (Alpha 13 20220724)
*** System upgraded to Debian 11 "bullseye" 64 bits ***
Added new DynaRes 15/25/31Khz video mode transformation
Added new DynaRes MAME TATE rotation patch
Added new DynaRes Interlaced Flicker Reduction
Added new DynaRes RGUI adaptative menu scaling support
Added new Scraper engine
Added new Scraper update system option
Added new Scraper capture system
Added new Slide Show screen saver
Added 2P LGun support for Arcade and Naomi/DC
Added new UI Bluetooth module manager
Added Naomi to LGun
Added DOSBox support for Roland(MT-32) and General Midi(SC-55) soundfonts. It requires new BIOS pack!
Added cheevos test mode (all achivements active on start)
Added new Slowdown Reduction emulation option
Added default Jamma6 mapping for Astrocity Mini gamepad
Added default Keyboard+Mouse support for all computer systems
Added new Game Menu combo button option in Controls option screen
Changed Hotkey button by Game Menu (home) button in mapping screen
Changed Save/Load/Exit hotkeys by new simplified RetroArch Game Menu via new Game Menu or Combo buttons
Changed default external unit formatting from FAT32 to exFAT (>8TB units, >4GB files, improved R/W performance)
Changed overclock from fixed to dynamic voltage
Changed several RetroArch translations
Changed Dreamcast from shared VMUs to per game VMU
Fixed Unknown BT controller devices detection (fix RetroBit bug)
Fixed analog L2/R2 mappings
Fixed NFS game joy mappings
Fixed system title on display rotation refresh
Fixed MAME inverted TATE game resolutions
Fixed scraper info unsupported chars
Fixed Ports launcher
Fixed local NFS not disabling RA menu
Fixed PSX Pad Type emulation option
Fixed C64 region aspect ratio
Fixed crash on Wifi region option
Fixed Emulation > Region option for PSX core
Fixed Favorites helper image refresh
Fixed several UI bugs
Fixed some translations (Argon msg)
Updated Scan Games BIOS blacklist
Updated Swedish lang
Removed RetroArch System option
Removed Keyb+Mouse emulation option
Removed Global NFS remaps
Removed XPADNEO Wireless driver
MicMey
MicMey
#66
Quelques photos de sessions de jeux sous RGB-PI Scart sur un écran cathodique Philips Black Line 21pt1663 (Photos prise avec GSM)
MicMey
#67
Pour ceux qui utilisent encore RGB-PI OS2, je viens de mettre a jour mon pack de skins avec 3 nouveaux skins "Super Video Idsa III"  Pour les installer bien lire le fichier "Readme for skins.txt" qui se trouve dans l'archive .RAR, ils sont sur le groupe Telegram mais aussi içi "23 Skins for RGPI OS2 Final V5 By MicMey [2020.12.12]" https://mega.nz/folder/aKQGRJKS#b4N19-jhkiqSyfnOnxo3uA
MicMey
#69
Petite partie sur "Fatal Fury Real Bout" 1, 2 et Special
MicMey
#70
Autres vidéos sympa, un gars utilise le RGB-PI avec l'émulateur Dreamcast Redream source Majisu
MicMey
#71
Plus de 70 nouveautés et corrections apportées au cours du mois de juillet/août à l'OS4 ALFa pour Raspberry Pi4/Pi400 uniquement. Chaque mois de nombreuses mises à jour sont proposé afin d'améliorer et de corriger le nouveau système "RGB-PI OS4" source RGB-PI Wiki (Changelog)
   Added Naomi to LGun
RGB-Pi OS 4 (Alpha 14 20220802)
   Added cheevos unofficial to Achivements Test Mode
   Added memory pack configuration to all four N64 controllers
   Added file name to scraper details view
   Added multiline support to scraper details view
   Added NeoGeo to Slowdown Reduction option
   Added SMS, NES, PCE, SNES Box arts and more scrap images
   Added improved information on mount error messages
   Changed PSX MemoryCards Types to Card1 = "Libretro", Card2 = "Shared"
   Changed Scan Games view translations
   Fixed LGun mouse index assignment
   Fixed Game Menu when connected to HiScore server
   Fixed SD card file and folder permissions
   Fixed joystick mappings messed up when L2/R2 are Btn and/or Axis
   Fixed crash when no audio device is available (Pi400 with no Jack)
   Fixed favorites title position
   Fixed wrong scrap image displayed when game has no id
   Removed Game Menu > Controls menu option when Kiosk mode is enabled
   Removed on screen boot error messages
RGB-Pi OS 4 (Alpha 15 20220807)
   Changed Game Menu to keep game running in global NFS
   Changed NFS slots from generic usage to specific Local and Global
   Changed mapping view to not save config when all buttons were skipped
   Changed FBNeo OC slowdown reduction to be enabled only in NeoGeo system
   Changed Game Focus (Keyb+Mouse mode) to Caps Lock key
   Fixed mappings for gamepads with analog triggers L2/R2
   Fixed NFS slot 2 unit
   Fixed mounting unit hang when using folder view mode
   Fixed crash when connecting a controller and LGun is already connected
   Fixed LGun UI internal mapping errors and combo buttons
   Fixed Game Menu button after playing in global NFS
   Fixed screen saver slideshow slowdown when selecting the same in display menu
   Fixed crash when font character is missing in fonts.dat
   Fixed favorites stopping working after scanning games
   Fixed bug preventing the mapping of analog joysticks in some scenarios
   Removed Game Menu options in global NFS
MicMey
Nouvelles mise a jour:
RGB-Pi OS 4 (Alpha 16 20220827)
Added Flycast to system region configuration
Added new Emulation > PSX Pad Type = DualShock Forced mode
Added new filter to avoid displaying multi disc/tape games so only m3u is displayed (requires rescan games)
Added new generation of /opt/rgbpi/ui/logs/error.log when UI crash happens
Added new scraper images for a7800, NES, SMD and ZX
Fixed some default joystick mappings
Fixed crash when disconnecting joystick ingame and returning to UI
Fixed rendering errors of UI special icons
Fixed RTK surface blitter crash in TATE mode
Fixed game info arrow indicator position in TATE mode
Fixed info text centering in TATE mode
Fixed Screensaver centering in TATE mode
Fixed Storage view text overlapped in TATE mode
Fixed themes genre icon font map
Changed Dreamcast BIOS from HLE to Native to make some games work (i.e. Sturmwind)
RGB-Pi OS 4 (Alpha 17 20220829)
Added core options menu
Fixed boot and scan games performance issue caused by screensaver slideshow
MicMey
#74
Citation de: Maitre_Poulpi le Mercredi 31 Août 2022, 02:46:34 AM
Merci de faire vivre le topic  ^-
De rien, chaque semaine j'apprends moi-même de nouveau truc sympa comme cette option qui permet de désactive la limitation des sprites sous Nintendo NES, en jouant à la compilation "TMNT The Cowabunga Collection" j'ai vu que Konami avait corrigé le problème du clignotement des sprites et je viens de me souvenir qu'il y avait cette option pour RGB-PI OS2 final 8)
MicMey
#75
Beaucoup de personnes demandent souvent s'il y a une option pour les jeux Nintendo NES qui évite le scintillement ou les clignotements des sprites quand ceux-ci sont affichés à l'écran. Sous RGB-PI OS2 final, quand vous lancé un jeu Nintendo NES, une fois le jeu lancé rendez-vous dans Retroarch, aller dans option et activer "NO SPRITE LIMIT"
J'adore ton côté emballé qui vend super bien son produit, mais le truc le plus top dans tes messages, ce sont tes photos, elles sont magnifiques!  :-*
MicMey
#77
Citation de: Wil2000 le Vendredi 02 Septembre 2022, 09:19:50 AM
Merci, oui j'aime beaucoup ce petit câble et le systèm RGB-PI OS, le rendu à l'écran est juste parfait, ça me change des câbles composites puis niveau jeux c'est bien sympa d'avoir plus de 120000 jeux (trié sans doublon) dans même pas 2 cm (SanDisk Ultra Fit), pour prendre la poussière c'est bien pratique. Je peux enfin finir pas mal de jeux grâce à l'option de sauvegarde et de chargement a la volée. Le truc sympa aussi c'est que tu peux créé tes skins toi même pour l'interface.
Pour les roms, j'avais déjà mes packs de roms a moi trié + les packs récent pour Everdrives disponible sur Archive.org ainsi que les roms Hack et traduite de chez Romhacking
MicMey
#78
Teenage Mutant Ninja Turtles Tournament Fighters sur Super Nintendo (RGB-PI OS2 Final)
MicMey
#79
Street Fighter 2'  SEGA Mega Drive (RGB-PI OS2 Final)
