Brancher un volant Sega Model 1 ou 2 sur un driving force Logitech
Démarré par Aganyte, Jeudi 19 Novembre 2009, 18:09:32 PM
Yes , it is correct. :)
Some have problems and changed R1,R2 to 3 kOhms, and add a 10 MicroF capacitor on the clutch. So buy them just in case.
PaTrYcK
wolfsoft
I am living in germany and sorry I can't speak france ;-) but google translator is my friend ;-)
I am so pleased by this post and so happy to see all fine Sega Games will run on one mashine
WONDERFUL.
I have some questions:
-Where i can get some PCBs of the L2M2
-Can you list up the game Cabinets with the right Steering wheel
MANY THANKS FOR ALL THIS WORK !!!!
PaTrYcK
#595
Hi wolfsoft  ;)
Citation de: wolfsoft le Mardi 20 Mars 2012, 21:23:19 PM
I bought it from Dan (etronicsfr@gmail.com)
Sure you can use:
Logitech driving force
Logitech driving force GT
Logitech driving force PRO
wolfsoft
Thanks for the fast response
What kind of Cabinets are suitable?
With the working right original Sega ForceFeeback wheels can be used?
Citation de: PaTrYcK le Mercredi 21 Mars 2012, 00:09:27 AM
Hi wolfsoft  ;)
Sure you can use:
wolfsoft
#598
thanks for the infos.
Only the first one (virtua racing, daytona usa, sega rally)?
Does the two other wheels working too?
wolfsoft
#599
BigPanik
wolfsoft
purplec1
Hi My friend retrorepair made a L2M2 board for me recently and im trying to connect it to my daytona steering panel.
Looking at the schematic to connect up the L2M2 board, I'm not 100%. Any help you can give would be great.
The 4 terminals on the board do they need to be connected as below.
1. 24 volt from Logitech plug power supply to Logitech and L2M2 (split and connect to L2M2)
2. Connect the 2 blue wires from the 6 pin amp connector on the sega wheel to the L2M2
3. Connect the 2 wires from the Logitech motor board (red & black) to the L2M2 board
4. Not sure about this one ( is this the brown and black wire from the motor)
Also the tutorial mentions about calibrating and U7, is it saying keep it connected for calibration or should it be removed.
Any help would be great thanks, I apologise for my lack of french
_n3o_
ptit up pour savoir si yavais de la news sur la "V2" du projet ? (enfin la version pas -1 du tuto ... meme si je sais pas si ca change grand chose)
Et pis aussi pour encore dire un grand bravo pour ce truc de grand malade.
Et pis aussi que bientot je m'y met aussi au L2M2 (ridge racer me manque trop) ...
Ah ptite question aussi, faut compter combien pour la PCB (chez Etronics, parceque j'ai pas tout pigé au system de prix)
Merci ;)
Ouép, faudrait que je jette un oeil à l'occasion. Pour les tarifs d'etronics, je ne me permettrais pas de les communiquer, libre à lui de facturer au grès du marché.
DragonsNoirs77
Je vais copier/coller mon dernier message ici (on sais jamais je pourrais avoir des réponses =:)) )
Je vais essayer d'expliquer un peu mon problème, lorsque je démarre mon pc, les leds D2 et D3 restent allumées en permanence, si je lance le panneau de configuration du logitech, elles s'éteignent et s'allume lorsque je demande un effet. Je referme ensuite le panneau de config et les leds restent allumées en permanence, et si je lance un jeux, elle ne s'éteignent que si un effet doit être fait (on dirais que ca fait l'inverse que cela devrais Sad )
J'ai malheureusement peu de temps cette semaine pour t'aider, on voit ça la semaine prochaine. ;)
DragonsNoirs77
Pas de problème, de toute façon je me demande si la carte n'aurais pas un problème, j'ai rebranché l'ancien moteur et ça fait comme je te dit, le moteur tourne en permanence, si je lance le panneau de config, il se stop et attend que j'appuie sur un bouton pour jouer un effet. Et si je lance un jeu des que je tourne le volant il tourne aussi donc la ça devrais être bon
