Auteur Sujet: Sega G-loc deluxe motor power supply  (Lu 22682 fois)
Hors ligne perjmolsen
  • Régulier
  • Willing to learn something new
« Réponse #96 le: Jeudi 25 Juin 2020, 12:58:09 pm »
  • Hi
    If someone needs the eprom code for the eprom that is located on the motor driver board.
    Then I have made a dump of my eprom
    https://www.dropbox.com/s/87oitu23utdpemj/Sega-gloc-motor-eprom-tms27c256.zip?dl=0
    It need to be burned on a 27C256 eprom.
    Kind regards
    Per
    « Modifié: Jeudi 25 Juin 2020, 13:00:30 pm par perjmolsen »
    Kind regards
    Per
    • Régulier
    « Réponse #97 le: Lundi 18 Janvier 2021, 09:32:41 am »
  • Hi
    Just a small update to the repair log, there is a typo R24 is a 2.2ohm NOT a 220 ohm
    https://www.dropbox.com/scl/fi/jdwr58zhg2tofkmensh2q/Nomenclature.ods?dl=0&rlkey=tm49vx0ax3kz10vesr5eg5ngx
    Kind regards
    Per
    Hors ligne ArcadeMachinist
    • Nouveau
    « Réponse #98 le: Jeudi 28 Janvier 2021, 06:50:44 am »
  • Hello everyone,
    I'm sorry for writing in English, but my French is 0.
    I'm trying to repair G-Loc motorboard, and little bit stuck, becuase my understanding of analog electronics is not so good.
    I have 2 board, one of them now work fine, anotherone has problems with delivering voltage to Q1 gate.
    On working board there is +3v after R21b, on the bad one - +0v
    Something is sinking +3v to Ground, so Q1 does not open.
    Also, on my board R23 and C15 are in series, not parallel as posted here before. D6 is reversed.
    My board had Q1 dead (blown), I have replaced it, also replaced L2 transformer with a new one, thanks to Per.
    I have changed C15, R23, ZD2, R25, PC1, D4, R22, C16, D6, R28, R27, ZD1, D5 and Q1 with new parts.
    Did not help. Something still sinks 3v after R21B to GND.
    If I (for testing) remove L2 transformer and R22 resistor - then Q1 gate gets exactly 3 volts, as it should.
    What can be wrong?
    All circuits after the L2 are tested and work fine.
    As a bonus info PC910 optocouplers can be replaced 1-to-1 with Everlight 6N137, they are the exactly same and tested to work fine.
    « Modifié: Jeudi 28 Janvier 2021, 06:56:51 am par ArcadeMachinist »
    Hors ligne gc339
    • Game Cheater
    « Réponse #99 le: Vendredi 05 Février 2021, 12:06:45 pm »
  • A l'époque où j'ai relevé le schéma du convertisseur BT, j'aurai dû accorder plus d'attention au schéma transmis par pn_jeux, il m'avait semblé à première vue trop dissemblable. J'aurai dû me rendre compte que la circuiterie autour du primaire du transformateur était quasiment la même ce qui m'aurait évité les erreurs qui ont été trouvées.
    J'ai donc redessiné ce schéma en corrigeant ces erreurs pour qu'il soit plus propre et plus compréhensible.
    @ArcadeMachinist
    Are you sure the new components are all OK?
    Have you checked them before soldering? Especially if they were bought from Chinese sellers on eBay or AliExpress.
    Are you also sure that one of the 15 volt power supplies is not shorted? Have you tried to unsolder diodes D3, D9..D11 one by one to check it.
    « Modifié: Vendredi 05 Février 2021, 12:22:30 pm par gc339 »
    Hors ligne f4brice
    • ✌(◕‿◕)✌ Donateur 2021
    • Historical Gamer
    • « Matériel inconnu ? Touche à ton cul ! »
    « Réponse #100 le: Vendredi 05 Février 2021, 12:10:25 pm »
  • J'ai donc redessiné ce schéma en corrigeant ces erreurs pour qu'il soit plus propre et plus compréhensible.
    Je trouve ce schéma fait main magnifiquement superbe !  :-*
    • Nouveau
    « Réponse #101 le: Samedi 06 Février 2021, 22:40:38 pm »
  • @ArcadeMachinist
    They are all new, from Mouser, not from China.
    I was testing them one-by-one with that transistor/diode/capacitor/resistors tester device.
    I have tested all secondary circuits, by removing L2, applying 18v from lab power supply to L2 outputs 11,10 and 14,13 -  checking that voltage regulators (IC5, IC6) correcty drive down this 18v to 15v.
    12v in case of "fan" output, all of them work.
    15v in case of 8,7 outputs.
    No shorts. L2 is new from Per.
    • Nouveau
    « Réponse #102 le: Lundi 31 Mai 2021, 19:27:48 pm »
  • In case anyone want's to sell me a spare board, or repair mine for a good price - let me know please!  >:D
