[BOARD] Universal FFB Controler
Démarré par Aganyte, Vendredi 31 Janvier 2025, 13:25:38 PM
manix
ead but upon finding this it may be best placed hereI posted this in another thrHello Guys, I hope English is OK as I am new to this board:) I'm here as I recently found out about the fantastic project to support original arcade hardware, in particular steering wheels and Force Feedback. I have recently managed to source original daytona usa cockpit (wheel, motor and gear shift), and pedals. I was originally planning to use an ultimarc a-pac to connect up, but from reading this forum it appears a new custom board (universal ffb maybe?), a PWM2M2 and arduino combination may be better as it supports FFB? I was wondering if someone could provide some information about this, if it's possible and if so, how could I purchase the required board? If I have posted this in the wrong place please let me know. thanks guys!
Phil26
#18
Bonsoir, j'ai un cab sega « jambo safari » sans board JVS.
Comment câbler correctement l'universal FFB controler?
Faut-il installer des pilotes pour que la carte soit détectées?
Je précise que j'ai acheté le SSD pré configuré avec la carte.
Tu as déjà l'uFFB en main ? Si oui, contact moi en mp et je te guiderai.
Phil26
Oui je l'ai déjà, elle est posé dans le cab et connectée en usb sur le Pc.
Je te contacte en MP, merci.
istrion
est ce que cette carte pourrait fonctionner sur une borne outrun chinoise ? ( le systeme a l'air propriétaire : https://ae-pic-a1.aliexpress-media.com/kf/Sd66658e7bb674be3b8b87d0a90c245fab.jpg_960x960q75.jpg_.avif )
J'ai conçu cette carte pour être universel, donc oui.
A Dude on The Internet
#23
Hello.
Just checking in on this project. I found my way here via KLOV from the U.S.
I currently own 2x Rush 2049s in working order.
What is the status of this project?
Is it at the plug and play stage if one orders the complete suite of parts with a configured flash drive etc?
What would the cost less shipping and whatever tariffs there are be for the complete kit for 2x 2049s?
I do understand pcs would be required on my end.
Also just out of curiousity since you have the skills. Have you considered an all in one unit that plug and plays in Jamma similar to the Chinese multi Jamma boards but for Jamma based Arcade cabs? I do also understand there are several interfaces and systems but Jamma being the most common.
I think this project is amazing and have been hoping for something like this for over 20 years.
Thank you
