Brancher un volant Happ sur un driving force Logitech
Démarré par Stef Bord, Mercredi 28 Octobre 2009, 21:33:00 PM
isamu
#624
Yeah, it's a bit annoying. I'm not sure what you mean by "current mod for AMC". While ingame, it is certainly there. I can feel the wheel wobble when it's in the center.
I am starting to get the feeling that the potentiometer on the Happ wheel is picking up interference from either the motor or the amp. Being so close to the motor and with that much power I think that may be the problem.
You know what I think *may* be a solution though? Running the ground cable directly to the steering pot on the Happ wheel. Who knows, maybe that will eliminate any interference being picked up allowing the needle to be more stable.
By the way, have any of you explored the idea of using the Logitech G25 pcb instead of the DF EX? Is it possible to replace the Happ steering pot with an optical encoder, and still have 270 degrees of rotation? And what about the motor signal? Would it need to use both motors or just one?
Or how about using the Driving Force EX pcb, but *only* replacing the Happ steering pot with an optical encoder? Would that work? Or would it be incompatible with the EX pcb?
Anyway my friend now has my happ wheel. He will complete the project by adding more ground wiring and I gave him another wheel to wire. I will be able to switch between two different wheels in a matter of seconds...sort of like a quick release type feature. I'm probably going to add a third wheel as well when I get a chance :D
Stef Bord
For G25 and DFP hack you must wait that V8Ben will make his wheel...
j'ai monté la carte du DF (non EX) dans la borne et les vibrations sont de retour. :'(
Le moteur et le volant de la borne ne sont pas les mêmes qu'à mon boulot (à mon boulot c'est celui qui vient de la sega rally italienne)
donc soit mon potar ou mon moteur pose problème soit l'agencement des câbles dans la bonne crée un problème de parasites....c'est pas gagné !  :-((
Edit (indice):
petit détail de barge, tant que je n'ai pas mis les pilotes logitech le problème n'était pas présent (aucune vibration avec les pilotes pourris de windows)
après avoir mis le pilote logitech c'était revenu.
Edit 2 (idée):
Stef, essaye d'enrouler les câbles du moteur de papier alu pour voir si ça change quelque chose. En aéromodélisme ont fait ça sur les récepteurs et ça marche bien
Stef Bord
#627
Pour l'alu, bien essayé Aganyte, mais déjà testé et sans effet malheureusement...
J'étais tombé dessus lors de mes recherches sur le net tout comme sur le système pour déparasiter un moteur...
J'avais même envellopé les autres cables, je te dis pas le souc dans mon boitier...
Tu as essayé de relier la masse qui court de l'ampli à l'alimentation du Logitech sur la partie métalique du moteur ? Isamu dit que çà a arr^té quasiment toutes ses interférences à part celles du potard...Au fait pour le potard c'est possible de connecter sa partie metallique à la masse ?
Quand au driver çà me laisse dubitatif...
Isamu for the potentiometer interferences do you use a 100K potentiometer ?
Citation de: Stef Bord le Samedi 27 Mars 2010, 19:18:04 PM
Non jamais essayé.
Le plus simple c'est de mettre la carcasse du volant à la masse (ce qui du coup mettra le moteur et le potard à la masse)
Stef Bord
isamu
Yes, I changed to a 100K pot. And yes, during testing I had no button interference only vibration on the needle.
My friend is going to add more ground and also put heavy duty cable skin over the wires to the buttons. I'll have to wait a few days before I get my wheel back home.
Stef I am looking forward to see what your results are with your grounding.
I seriously wonder if grounding the steering pot itself would eliminate the vibrations. Guess I'll have to wait and find out.
I'll tell you one thing though....it would be absolutely BEAUTIFUL if we could replace the Happ steering pot with an optical encoder and still use the same analog signal from the Driving Force EX PCB. Wouldn't that be nice, Stef? :)
Stef Bord
Why do you want to replace an analog potentiometer 100K with an optical encoder ? I understand that for a 900° wheel but with our 270° wheel it is not so important.
The 5k potentiometer is very precise whan i connect just the logitech USB without the motor...
isamu
If it turns out the pot itself is what's picking up interference, shouldn't getting rid of it altogether and replacing it with an optical encoder allow for a much more stable analog signal without any interference? Well, it probably wouldn't work so well with the EX pcb but who knows?
Citation de: isamu le Dimanche 28 Mars 2010, 18:12:53 PM
Pour ça il suffit de brancher un condensateur entre la masse et le point milieu du potentiomètre. Pas trop gros pour éviter d'avoir un temps de latence trop important.
Edit: Cela me donne une idée, cette semaine je vais collé un Ampli op monté en suiveur sur le point milieu du potentiomètre et juste après le suiveur un circuit RC (avec R variable) puis je ferais quelques tests en modifiant la fréquence de coupure pour voir si ça apporte quelque choses  ;)
Stef Bord
Ce que je n'arrive pas à comprendre c'est que ce potard dans les bornes Midway a la même place à coté du moteur et il n'y a pas d'interférences. Or le mode de fonctionnement est peu ou prou le même. il y a bien les fils du potard qui passent à coté du moteur et qui vont sur une carte electronique.
Comment font ils pour ne pas avoir de soucis ? Je n'ai pas vu de cables blindés tant dans le Happ italien que ma version américaine...
Ce qui me parait logique sur ce genre de borne c'est déjà mettre la carcasse du volant à la terre (par sécurité pour l'utilisateur) et certainement quelques filtres par çi par là. A nous de faire pareil  ;)
Stef Bord
Je suis tombé sur Amazon sur le Thrustmaster Enzo Force Feedback Racing Wheel à 25€.
M'en suis pris un j'ai bien envie de voir comment c'est foutu dedans et si les mêmes problèmes se posent qu'avec le Logitech...
Mon premier FFB c'était un Thrustmaster et j'en garde un très bon souvenir dans le rendu...
Stef Bord
C'est un miracle, je viens de mettre la carcasse du volant à la masse de l'ampli et plus de vibrations dans le volant, j'espère que çà va être pareil pour les touches... :-)=
isamu
Citation de: Stef Bord le Lundi 29 Mars 2010, 17:57:56 PM
CitationIt is a miracle, I have just put the carcass of the wheel at the mass of the amplifier and more vibrations in the wheel, I hope that that will be similar for the keyS.
Stef this is probably a mangled translation, but can you tell me what he means by "Carcass of the wheel", and is he saying he is now getting more vibrations or less vibrations?
Also Agantye, does your amp have pots to adjust the power, such as "VCS Gain", "Current Limit", etc?
