[BOARD] Tilt Audio, une alternative à PinSound
Démarré par Aganyte, Lundi 20 Décembre 2021, 13:39:00 PM
Roverius
Hi,
I have a tiltaudio board v3.10 with firmware (software) v1.42b
i use a RPi 3A+
I want to run this on a DataEast Lethal Weapon 3
The problem is, the sound does not syncronise whit the game or just continue to play the same soundfile until something else is triggered.
Also, i am unable to change volume with the sound potmeter inside the cabinet.
Asking Steve for support does not help, i don't get any answers.
I am trying to find a previous version, like v1.38 or so to try it out.
So, if anyone can help met out with this v1.38 i would realy appreciate this.
Thank you!
Sebinouse
#257
I don't have my Tilt audio around but is this what you are looking for : https://tiltaudio.com/files/update-1.38.zip ?
Roverius
No, this file is only a update if you have dietpi running on the board.
The software/firmware i want is maybe a image of the working SD card that still runs on DietPi and not on the newer OS 1.42b thathas many problems.
Anyway, thank you for the response :)
Roverius
@StarLord Thank you very much for the effort and time.
I will try this out and leave a comment after the test.
Best regards,
Roverius
@StarLord
I had to alter the image for the RPi a bit because it didn't boot.
After the adjusments, the Rpi boots into Tiltaudio
But, the dietpi root password has been changed and i can not SSH or use Putty to adjust things.
So, can i get the password?
You can mail it to me if needed roverius@telenet.be
Thank you
StarLord
Citation de: Roverius le Lundi 05 Octobre 2026, 16:17:19 PM@StarLord
Thank you
It is the default password :
ssh pi@192.168.42.1
password is pi
Roverius
thank you
It is running but no sound. Choosing a audio card gives errors.
I will see what i can do.
StarLord
Try to see the log file, you should find some information...
Roverius
@StarLord
Sound is working now.
I had to update the Kernel and the overlay files.
I will make a image of the working SD-card.
i enabled the NTP to get the real time instead of the 2021 date.
Also, i am going to set a fixed ip instead of dhcp.
Thanks again for the file :)
