Brancher un volant Sega Model 1 ou 2 sur un driving force Logitech
Démarré par Aganyte, Jeudi 19 Novembre 2009, 18:09:32 PM
L2M2 is an old hack. You can try Pwm2m2 if you have anytime  ;)
mR_CaESaR
Citation de: aganyte le Jeudi 11 Octobre 2018, 07:31:22 AM
Yeah understand L2M2 is very old and outdated. I may look into the new version at some point, but I'm a total newbie and we were lucky enough to have L2M2's made by someone in Australia. The PWM2M2 seems A LOT more daunting than the L2M2 :)
If you need, i sell the Pwm2m2 board complete and ready to run for 40€ (without shipping)
mR_CaESaR
#1027
Ok. So I'm reporting back!
I know this tech is really old and outdated, but I just got my hands on it and a racing cab and I was wondering if there are others that have come across my issues/behaviour
I have a squeaking on when I turn the wheel to a complete stop on the ccw side. Changes to the RV4 didn't take the squeak out, I have a feeling I'm going to have to adjust the belt?
I also made the changes listed in the byoac thread and also increased the ffb in profiler to 150% for global ffb settings, made sure centering is checked and it's so much better.
Here it is in the profiler..
https://youtu.be/4DyLOGVDhDk
And here it is in game (of course it's daytona :D)
https://youtu.be/lZ8ADfYKSRY
I think I'm pretty close to completing the wheel mod, just have to get the pedals working so I can actually sit down on the thing!
I'm wondering if this the same type of behaviour that's expected from the L2M2? Is the wheel supposed to stay engaged when turned to absolute right or left? Or should it re centre?
Any help would be greatly appreciated!
Thanks.
Ps my ini file for m2 emulator is as below
Citation
;FORCE EFFECTS PARAMETERS
;FE_CENTERING Effect (Spring centering effect)
FE_CENTERING_Gain=1.0      ;Global gain FE_CENTERING_Coefficient=10000   ;0-10000
FE_CENTERING_Saturation=10000   ;0-10000
FE_CENTERING_Deadband=100   ;1%
;FE_CLUTCH Effect (Friction, wheel turn hardness)
FE_CLUTCH_Gain=1.0      ;Global gain
FE_CLUTCH_Coefficient=10000   ;0-10000
;FE_LEFT,FE_RIGHT (Constant force in a direction)
FE_LEFT_Gain=2.0      ;Global gain
FE_LEFT_Magnitude=10000      ;0-10000
FE_RIGHT_Gain=2.0      ;Global gain
FE_RIGHT_Magnitude=10000   ;0-10000
;FE_UNCENTERING (Sine force, wave the wheel, rumble)
FE_UNCENTERING_Gain=10.0      ;Global gain
FE_UNCENTERING_Magnitude=10000   ;0-10000
FE_UNCENTERING_Offset=-200
FE_UNCENTERING_Phase=0
FE_UNCENTERING_Period=56000
Edit: bandicoot helped me out and said I needed to swap around my cw and CCW wires. Everything is now working as if should!
https://youtu.be/mcq3nvgrxD0
bandicoot
Mon pincab
