[BOARD] Core Blaster 32, une alternative à PinSound
Démarré par Aganyte, Lundi 20 Décembre 2021, 13:39:00 PM
Roverius
Hi,
I have a tiltaudio board v3.10 with firmware (software) v1.42b
i use a RPi 3A+
I want to run this on a DataEast Lethal Weapon 3
The problem is, the sound does not syncronise whit the game or just continue to play the same soundfile until something else is triggered.
Also, i am unable to change volume with the sound potmeter inside the cabinet.
Asking Steve for support does not help, i don't get any answers.
I am trying to find a previous version, like v1.38 or so to try it out.
So, if anyone can help met out with this v1.38 i would realy appreciate this.
Thank you!
Sebinouse
#257
I don't have my Tilt audio around but is this what you are looking for : https://tiltaudio.com/files/update-1.38.zip ?
Roverius
No, this file is only a update if you have dietpi running on the board.
The software/firmware i want is maybe a image of the working SD card that still runs on DietPi and not on the newer OS 1.42b thathas many problems.
Anyway, thank you for the response :)
Roverius
@StarLord Thank you very much for the effort and time.
I will try this out and leave a comment after the test.
Best regards,
Roverius
@StarLord
I had to alter the image for the RPi a bit because it didn't boot.
After the adjusments, the Rpi boots into Tiltaudio
But, the dietpi root password has been changed and i can not SSH or use Putty to adjust things.
So, can i get the password?
You can mail it to me if needed roverius@telenet.be
Thank you
StarLord
Citation de: Roverius le Lundi 05 Octobre 2026, 16:17:19 PM@StarLord
Thank you
It is the default password :
ssh pi@192.168.42.1
password is pi
Roverius
thank you
It is running but no sound. Choosing a audio card gives errors.
I will see what i can do.
StarLord
Try to see the log file, you should find some information...
Roverius
@StarLord
Sound is working now.
I had to update the Kernel and the overlay files.
I will make a image of the working SD-card.
i enabled the NTP to get the real time instead of the 2021 date.
Also, i am going to set a fixed ip instead of dhcp.
Thanks again for the file :)
Voilà la toute première Core Blaster 32 qui est donc compatible avec le Tilt Core.
En action
Par rapport à une Tilt Audio, démarrage instantané, pas de système d'exploitation (la carte SD ne contient que les fichiers audio), reprise du son de démarrage d'origine typique des Bally/Williams. Pour le moment compatible WPC/WPC-S et WPC95. Je travaillerai sur l'ajout de Data East puis White star dans quelques temps.
Sebinouse
Pour le branchement des HP c'est comme les TiltAudio (Stéréo) ou comme les originaux (Mono + Tweeter) ou les deux ?
StarLord
Magnifique carte ^-^  Pour avoir testé la Tiltcore, je peux vous dire que cette carte est une tuerie :D  On se retrouve avec la même configuration qu'une carte d'origine (même comportement, même rapidité d'allumage) avec en plus un son d'enfer bien meilleur qu'à l'origine (surtout si vous mettez de bons HP et un bon woofer) :-)=
StarLord
Citation de: Sebinouse le Mardi 13 Octobre 2026, 07:29:37 AMPour le branchement des HP c'est comme les TiltAudio (Stéréo) ou comme les originaux (Mono + Tweeter) ou les deux ?
Oui, tu le vois sur la photo, comme tiltaudio  :D  RIGHT+ RIGHT-, LEFT+ LEFT- et SUB+ SUB-
Sebinouse
Bon j'avoue c'était une demande déguisée ... mon but est de rester le plus proche de l'original
