Hi All,
(Sorry for English, my French is really really bad).
I have been working on setting up an Initial D5 cab with the FFB Pro board. I have an issue and a question:
- The wheel pot seems to behave very erratic in vjoy/backforcefeeder. It's not stable, and when I turn the wheel, the value goes all over the place. What could that be? The brake pedal and gas pedal are also somewhat 'nervous' but much more stable compared to the wheel. None of them are completely stable though: constant change in value, even when not touching anything. This scenario is visible even if I only have the FFB Pro connected to the PC via USB, and the controls from the cab connected to the board. The serial motor drive is not connected during the test.
- I don't yet understand how to connect power. Am I supposed to connect a power source to the MOLEX on the FFB Pro? It seems the USB connection also delivers 5V to the PCB? My PC will not turn on at all when I connect the MOLEX and USB at the same time. It is probably detecting that issue (as a short of some kind..?) Are there any diagrams showing how to connect the FFB Pro to the different power sources?
Thanks!
