FFB CONTROLLER PRO + PC
Démarré par simulate, Vendredi 06 Août 2021, 10:53:48 AM
simulate
Citation de: Tibal le Lundi 09 Août 2021, 18:32:09 PM
No, it's the other way around
FFB PRO
pin5>>tx-
pin6>>tx+
pin7>>rx-
pin8>>rX+
The test does not work, guess sega midi failure
Thanks~
Own Vewlix initial D
For me, this is not the good order.
Please double check the connection order. On the midi board, the pin 1 is identified by a triangle.
FFB Controller   -> Midi board
       Rx-                    5
       Rx+                   6
       Tx-                    7
       Tx+                   8
On the FFB Controller, you can read the name of the pin directly on the PCB.
simulate
Citation de: Aganyte le Mardi 10 Août 2021, 07:28:40 AM
       Rx-                    5
       Rx+                   6
       Tx-                    7
       Tx+                   8
Cool, the system caught the midi version, and the steering wheel is currently corrected. Fortunately, the sega midi board is not abnormal.
thanks~
simulate
Citation de: Aganyte le Mardi 10 Août 2021, 15:28:19 PM
Which pin is the JST RA on the left and right of the steering wheel?
My lines are cut off, I don't know which pin is,
Query google to get the following
19 (1P Right)
20 (2P Right)
21 (1P Left)
22 (2P Left)
23 (1P Up)
24 (2P Up)
25 (1P Down)
26 (2P Down)
But the left and right sides of 1P and 2P cannot work normally.
I don't know which pin position corresponds to the left and right side of the sega pro
Thanks~ ^-
Please use Sega Race TV schematics and "Midi+4 views" firmware.
simulate
I have completed these settings, but ffb does not work properly in the game. Which step am I missing?
The game uses M2emulator
There is an open FFB project
Thanks~
On ne peut pas t'aider avec si peu de détails.
simulate
Citation de: Aganyte le Vendredi 20 Août 2021, 20:17:21 PM
Successfully connected to ffb, the motor rotates to the right
I set it to PWM_CEN
Can only choose default
M2emulator_1.1a successfully identified the vJoy device
Open FFB mode
But there is no FFB feedback effect in the game,
What am I missing?
Sorry for the trouble
Thanks~
Sur ce coup là, je ne peux pas t'aider. J'ai pris le SSD de dvseb et tout été déjà réglé. Par contre, certains ici devraient pouvoir te répondre.
Tibal
In njz3 archive, there is a tool (i can't remember its name) to test the ffb effects. You should try it.
If it works with this tool, then maybe try an other ROM of Daytona, or try sega rally, as there is a version of Daytona that does not support ffb.
You may have to create a control set for each game you try (not sure though)
If it doesn't work with the tool, sorry, I can't help you.
simulate
#27
How to use njz3 tool to test ffb effect?
simulate
Working fine
Test Daytona USA can work normally!!
Very good machine board,
Test other games
thank you all ^-^ ^-^
Aganyte is awesome!!! ^-^ ^-^
simulate
Do you support mame?
Using ffb arcade plus 2.0.07, mame.ini is set up, and ffb cannot work normally when opening the game
Or am I missing something? :'(
thanks
Yes, it work with my Dvseb SSD (probably with Boomslang plugin).
