FFB CONTROLLER PRO + PC
Démarré par simulate, Vendredi 06 Août 2021, 10:53:48 AM
simulate
838-14174 midi drive
FFB CONTROLLER PRO
Initial D3 Motor
How should I connect them correctly so that they can work normally on the PC
Is there a schematic reference?
What am I missing?
Thanks
simulate~
Own Vewlix initial D
Tibal
To answer your personal message, here are some more information from my personal experience, but they are mostly specific to the NON-PRO version of the FFB Controller :
https://www.gamoover.net/Forums/index.php?topic=43434.0
However it should help you a bit to understand how everything works.
If you need explanation or translation, feel free to ask here.
Good luck !
simulate
#3
IO version link left right
What did I miss?
Have you flashed the Sega FFB Pro ?
simulate
I flicked PC_To_SegaFFB MIDI,
But enter 3 in the cmd window,
The equipment is com3,
Is this correct
Thanks~
The com port depend of your computer. Can you tell me if the led on the Sega FFB pro is blinking ?
simulate
#7
The pc uses the win10 ltsc version, the ffb pro light is flashing, and the system will be tested after reinstalling
njz3
The log of the BackForceFeeder shows that the communication between the PC and the mega on the FFB Pro does work correctly, since the board reports its version.
It fails when the steering wheel initialization command is sent, which probably means you have a communication issue between the FFB Pro and the servoboard.
simulate
838-14174 driver link as shown
ffb pro connect TX+ TX- RX+ RX-, is this correct?
What am i missing
Tibal
It's a too low quality to see, but you should have :
pin R- R+ T- T+ of the FFBC respectively connected to pin 5 6 7 8 of the driveboard
simulate
Citation de: Tibal le Lundi 09 Août 2021, 10:50:54 AM
yes~
There are new problems in reinstalling win10
njz3
The new BFF 0.5 outputs more log messages, and error is the same : initialisation of the servoboard failed.
simulate
Citation de: njz3 le Lundi 09 Août 2021, 15:40:13 PM
Taiwan power supply is 110V
I don't speak english sorry~
simulate
FFB PRO
pin5>>tx+
pin6>>tx-
pin7>>rx+
pin8>>rX-
is it right or not
I guess the sega midi may be faulty :P
