FFB CONTROLLER PRO + PC
Démarré par simulate, Vendredi 06 Août 2021, 10:53:48 AM
simulate
mame is working normally, the version is wrong, and the replacement version to 0.199 has worked normally, ^-^
May I ask the setting of the lamp, is the connection of View1 Lamp + gnd normal?
The bulb uses 6.3v
mame64.exe outrun -output windows
Use the internally set Control Set
The code does not work properly, which side of me is wrong?
thanks for the reply
Own Vewlix initial D
njz3
Hi simulate,
First test your electronics and lamps by manually activating the outputs from the BFF.
To do that, open the BFF in the "Outputs" page, then click in the checkbox on the left and see whether your lamps are lighted.
If this does not work then you have a hardware issue.
If this test is a success, then please try to follow how to configure a game from the tutorial of gojirien.
Please give screenshots of your software configuration.
simulate
hi njz3
I used your method, but the light does not work,
I didn't use ULN2003, only sega FFB Pro provided by Aganyte,
Foot use
START LAMP+GND
VIEW 1 LAMP+GND,
Do you still need ULN2003 to work normally?
Thanks~
dvseb
Foot use
START LAMP+GND
VIEW 1 LAMP+GND
It's false !
The Good is :
START LAMP + + 5V
VIEW 1 LAMP + + 5V
On the ffb pro : start lamp is : pin 51 and view 1 lamp is pin 53
Citation de: simulate le Jeudi 16 Septembre 2021, 13:57:29 PM
The ULN2003 is include in the Sega FFB Contoller Pro.
simulate
hi dvseb
You are right to work properly ^-
Thanks to Aganyte. njz3. dvseb for the instruction
Learned a lot of knowledge
thanks ^-^ ^-^
