Brancher un volant Happ sur un driving force Logitech
Démarré par Stef Bord, Mercredi 28 Octobre 2009, 21:33:00 PM
J'ai posé la question à Shige de chez Frex pour une date pour le wheel adpater
http://frex.xsrv.jp/xoops/modules/newbb/viewtopic.php?topic_id=386&forum=8
Donc çà arriverait début Mai mais la formule à changée, le kit de palettes sera vendu avec le quick release set qui coûte un oeil :(  (plus de détails dans le lien)
Wait and see....
mentalmike
Hi, sorry for writting in English! I am going to try out this mod and wanted to make sure I understand everyting. I have read the whole of this post through google translate.
From my understanding there are two ways to make the happ work. First way through an AMC amp - supply the logitech PCB with 12v and the AMP with 24v. Am I correct in understanding that this way will produce vibrations when the wheel is centered?
The second way is to make a custom PCB as shown here. Which version is best as several are shown?
My main question is which creates the best results? Is it possible to avoid the vibration with the amp or the custom pcb? I currently have a logitech driving force ex and a AMC 30a8 amp so I will be trying that out, but wanted to know if the custom PCB will create better results?
Thanks for any advice!
Stef Bord
For the vibrations, if you use the wheel with the PC like me, you can with the setups of the games avoid these vibrations. I haven't tested yet the Aganyte card so I don't know if the vibrations dissepear completely...
Aganyte, il y a toujours avec ta carte les petites vibrations perceptibles quand on est proche du point central en mettant un doigt sur le volant lorsqu'on active le retour au centre du volant ?
Elles ont quasiment disparu, c'est même pas suffisant pour me secouer la main.  :D
mentalmike
Thanks for the info! I think I'm going to try and make agante's PCB. Where can I find details of the most current version?
I found this post here. From looking at the dates I'm guessing this isn't up to date with newer versions in this post.
Thanks for the help!
V8 Ben
Hi MentalMike,
If I can give you an advice, I think you can start your mod with the AMC. You have everything at hand, you just need some wires... a little bit of time and patience... and it's done ;)
Stef could give you the settings for AMC.
Test it, and if you're not satisfied, it will always time to make an Aganyte's board.
mentalmike
Hi Ben,
Am I right in thinking I'll have to change these settings everytime I change game in the logitech control panel?
I've only just found this post that uses the sega steering unit. Does anyone know how this compares to the happ as I have two of these from my Daytona cabs. I need to read that post properly to see what's involved to make it work but may make one of those to compare with the happ as at some point I intend to make both my Daytona cabs work.
Stef Bord
#1095
If you use sega model wheel, you must use too the Aganyte special board.
Aganyte has tested the two steering wheels sega and Happ and the Sega is very powerful. But the Happ is very good too. The more easy system is the happ and it's very cool with arcade games like Daytona etc...
You have not to change everytime you play the games with this system but yes the Logitech control panel can make that for the differents games if you are not happy with the standard AMC setup that you have made the first time...
You will just play arcades games Daytona, Sega Rally etc...with emulator or PC games too ?
mentalmike
Hi Stef,
I have read the sega post and I think I am going to give that a try. I have two cabinets that I want to get working so I will compare happ with amc and sega with aganyte's board. If I prefer the happ I will look to make aganyte's board for that.
Thanks all for the help. I will let you know how I get on!
Tiens, les gars, j'ai choppé un T500RS à prix modique, si vous voulez que je l'ouvre pour regarder comment il est branlé...
(J'ai pas lu tout le topic donc je sais plus où ça en est mais comme un moment vous en parliez...)
toto44
Pour t'éviter de le démonter, V8Ben l'à fait sur RFR.
Okay, merci ^-^
Faut que je le teste un peu plus en profondeur ce volant, mais il a l'air assez sympa :D
V8 Ben
Vi vi, il l'est  :D
Mais je dois tout de même avouer que la rotation est quand même moins fluide qu'avec un HAPP... Plus je l'utilise, et plus je me dis que le moteur est sous-dimensionné.
Certes, il est puissant, mais pour atteindre cette puissance, ils ont dû mettre des aimants énormes. Et du coup, on sent quand même légèrement les crans lorsque les effets sont faibles.
C'est pas forcément gênant, mais si on y fait attention, on le sent.
J'ai hâte de pouvoir comparer avec le HAPP...
Vu que je n'ai que ça comme volant, je vais faire avec... C'est un achat complètement imprévu donc j'ai quasi aucun jeu pour le tester... Obligé de taxer un GT5 à un collègue pour essayer :D :D
Tiens, tu me diras si il dé-calibre en pleine course.
J'ai un problème et d'autres ont le même avec plusieurs volants : Tu commences la course avec le volant au centre et tu finis avec avec une bagnole qui tire méchemment à droite  >:(
Et ce n'est pas une histoire de physique
Heureusement que j'ai jamais eu ce genre de problème sur ma borne, ça à l'air bien casse c....
