Auteur Sujet: [Beta] - BackForceFeeder : feeder vJoy FFB pour racecabs  (Lu 31824 fois)
Hors ligne njz3
  • ✌(◕‿◕)✌ Donateur 2021
  • Pilier
« Réponse #624 le: Mardi 20 Juillet 2021, 14:57:31 pm »
  • Sorry, I mainly developped the software for emulators that runs on Windows, not on raspberry...
    The vJoy driver (virtual joystick) I use in the BFF is only available on x86 or x64 Windows computers.
    As a side exploratory project, and since forcefeedback stuff is now a lot easier to develop that it used to be 2 years ago, it is possible to transform an Arduino to a forcefeedback racing wheel device.
    Some people have been successfull to use STM32 boards for DIY steering wheels, and I personnally played with a Leonardo and a Due to make it seen by Windows as a steering wheel (no vJoy in this case).
    This could perhaps make it compatible with a raspberry or a console compatible wheel, faking a commercial PID/VID.
    The Leonardo board is a bit limited in its processing power to handle complex forcefeeback stuff with advanced digital filters, USB communication, and PC communication (to transfer configuration data and lights).
    The main issue for other more powerfull boards like the Due or STM32 boards is they are 3.3V microcontrollers, thus analog or digital 5V level signals from our arcade cabinets must be shifted back to 3.3V.
    « Modifié: Mardi 20 Juillet 2021, 15:06:04 pm par njz3 »
    Hors ligne nonosto
    • Accro
    « Réponse #625 le: Vendredi 30 Juillet 2021, 07:35:20 am »
  • J'ai ce volant pour Lindbergh, la ref est SPG-2001X  STEERING WHEEL, et il semble très proche du model 3 SPG-2001 STEERING WHEEL;
    2 questions svp:
    - est il compatible avec le kit model3?
    - dois je ajouter un ventilo?
    Hors ligne dvseb
    • Pensionnaire
    « Réponse #626 le: Vendredi 30 Juillet 2021, 08:24:50 am »
  • Salut,
    J'ai eu le même dans ma borne.
    C'est un volant qui est de type model 3, on le trouve dans les bornes lindbergh (outrun 2, rtuned, sega race tv, etc...)
    Il marche parfaitement avec les cartes FFB controller d'aganyte et le soft Backforcefeeder de NJZ3.
    Il a une réactivité plus violente que les moteurs utiliser par sega sur les scud race, daytona 2, f355 ou sega rally 2...
    Hors ligne njz3
    • Pilier
    « Réponse #627 le: Vendredi 30 Juillet 2021, 11:27:27 am »
  • Merci Seb
    Est ce que le volant a un débattement similaire au moteur model 3 ?
    Hors ligne dvseb
    • Pensionnaire
    « Réponse #628 le: Vendredi 30 Juillet 2021, 12:31:16 pm »
  • il est completement identique, absolument aucune difference.
    Out run 2 sp sur chihiro utilise le meme bloc volant moteur que scud race
    Out run 2 sp sur linbergh utilise le meme bloc volant si dessus rtuned-segaracetv
    Hors ligne nonosto
    • Accro
    « Réponse #629 le: Vendredi 30 Juillet 2021, 13:54:53 pm »
  • MERCI bcp, du coup est ce un bon volant?
    Du coup avec les paramètre qui reproduisent le FFB en fonction du jeux du soft Backforcefeeder de NJZ3 sa pose aucun problème, on a les même retour?
    Hors ligne nonosto
    • Accro
    « Réponse #630 le: Vendredi 30 Juillet 2021, 14:24:40 pm »
  • Ah oui pour le ventilo stp?
    Hors ligne dvseb
    • Pensionnaire
    « Réponse #631 le: Vendredi 30 Juillet 2021, 18:10:22 pm »
  • Ca fonctionne pareil que le volant scudrace.
    ventilo non nécessaire sur ce modelé.
    Hors ligne nonosto
    • Accro
    « Réponse #632 le: Vendredi 30 Juillet 2021, 18:44:51 pm »
  • Merci
    j'ai reçu sa avec je me demande c'est quoi?
    « Modifié: Vendredi 30 Juillet 2021, 18:53:00 pm par nonosto »
    Hors ligne psyko44
    • Confirmé
    « Réponse #633 le: Samedi 31 Juillet 2021, 12:36:05 pm »
  • Je crois voir d ou il vient  :D
    Je suis intriguer aussi par le sachet, surement du spare dediée a la borne.
    « Modifié: Samedi 31 Juillet 2021, 12:45:59 pm par psyko44 »
    Hors ligne 6rk
    • ✌(◕‿◕)✌ Donateur 2020
    • Accro
    « Réponse #634 le: Samedi 31 Juillet 2021, 22:47:43 pm »
  • Merci
    C'est pour relier une single à une service box. Étrange que ça soit livré avec un panel. Il vient de où ?
    SNK MVS-U2/25 //// MVS / RPI2JAMMA
    TAITO EGRET 3 //// NAOMI 2 NETBOOT / RPI2JAMMA
    SEGA NUC //// VIRTUA TENNIS 1 / RPI2NUC
    SEGA RALLY TWIN HD //// WIP en cours / FFB CONTOLER + PC MULTI
    RECHERCHE :
    - Sega Mini Medal Game Manpuku Suizokukan / Goldfish
    - Sega Lindbergh cabinet
    - Pachislot
    Hors ligne nonosto
    • Accro
    « Réponse #635 le: Samedi 31 Juillet 2021, 23:59:11 pm »
  • C'est un panel soit disant neuf pour SEGA Race TV, gagner sur une enchere jap.
    Hors ligne nonosto
    • Accro
    « Réponse #636 le: Dimanche 01 Août 2021, 15:39:33 pm »
  • Le driver Windows est vJoy (c'est un joystick virtuel), ce n'est pas compatible avec une xbox 360.
    Sauf peut être avec un Gimx mais je ne peux pas encore aider là dessus.
    pas d'Xbox avec GIMX
    Je reviens la dessus svp, je suis pas bien sur de comprendre le fonctionnement en output vJoy envoi quoi comme info à l'OS? Si il s'agit de souris ou clavier Gimx fonctionne sur xbox, PS3....
    Hors ligne Popo69
    • Régulier
    « Réponse #637 le: Samedi 25 Septembre 2021, 10:12:16 am »
  • Hello suite discussion par mail mon moteur ne bouge pas une oreille le volant ne bouge pas suite connexion selon procedure avec la carte ffb et ma arduino. Le reste marche je peuxjouer sans probleme mais aucun retour de force. Help
    Hors ligne njz3
    • Pilier
    « Réponse #638 le: Samedi 25 Septembre 2021, 20:33:22 pm »
  • @nonosto: vjoy est un joystick HID virtuel qui est vu sous Windows comme un joystick DirectInput. Ce n'est pas un clavier ni une souris. Vjoy n'envoit rien à l'OS, il stocke les informations du joystick qui sont ensuite lues par les jeux.
    @popo69: vu que tout fonctionne au niveau axes et boutons, je suspecte un soucis de communication entre le mega et le pwm2happ, ou un mauvais code dans le pwm2happ.
    Hors ligne Aganyte
    • ✌(◕‿◕)✌ Donateur 2021 WIPeur compulsionnel
    • Staff
    • Dieu de l' Arcade
    « Réponse #639 le: Samedi 25 Septembre 2021, 20:35:26 pm »
  • Le code dans le pwm2happ est bon, par contre je ne sais pas si Popo a coché la case "digital pwm".
