Pour la peinture, il est vrai que le mdf brut va agir comme une eponge.
Je vais voir à mettre du sintobois comme le conseil aganyte.
Sur arcadecontrol, il conseil du Bondo (sorte de mastic pour voiture)
Je vous met le texte original d'un des membre Ond qui fait des merveilles en matière de finition et de projet:
"I don't how many times I've seen questions and different approaches to preparing and painting MDF.
Getting a good result with MDF need not be a horror story, just a process that addresses the nature of the material.  This is especially true for complex shapes, rounded corners etc.  Just a coat of primer and then a coat of paint will most likely result in the all too familiar finish folks refer to.
I wouldn't recommend using dry wall compound, MDF dust and glue, wood filler     to prepare MDF for painting.  They are ALL too soft and porous for a good surface finish.  You can get a very good finish on MDF using auto products.  Non water based Auto Products people!     This means filling nail holes, pits etc with Bondo (or its equivalent), sand back and spray surface with Spray Putty (Pre-Primer treatment), then  Auto Primer, then paint.  Soaking up problems etc all disappear with this approach.  You also end up with a harder surface on which to sand, paint, polish etc.  My Goal with MDF or any construction material for that matter (including Plywood) is to end up with a surface where folks take a look and say "what's that made out of?".  Leaving no clue as to the materials used.   You want that surface ready for any final look, metallic, glossy, plastic – whatever.   Is it expensive?  Well it's more expensive than acrylic primer and home depot house paints.   If in doubt, check the results I got on my CP finish as an example"
Ond.
Je garde bonne espoir du résultat au vu de ca (sans aller aussi loin) :
http://shoryuken.com/f177/how-paint-mdf-mirror-finish-worklog-191692/
padawan
Un aprêt Epoxy devra isoler les fond, prends le bien épais , applique le (au pistolet)...
et ensuite, après séchage, ponce le afin d'avoir une couche de produit lisse, ça va effacer "le grain" d'épaisseur et te donner une belle surface pour ta finition  ;)
ça deviens vraiment un WIP de légende là...je pense qu'on se dirige vers un cru exceptionnel en "qualitay"  ^-^
ben alors ? plus de news depuis le 19 janvier ?  :?
Bon, j'avance à petit pas en ce moment, beaucoup de réflexion et peu de temps libre..... >:(
Stage 4 : Le CPO
Bon, je m'attaque donc à ce panel:
Au départ j'étais parti sur un CPO en MDF 10mm (sauf le panel du dessus en 19mm bien sur)
Mais Yannick60 m'as rappelé que l'original est bien plus arrondis, et mon panel n'est pas très ressemblant au final...
Bon on efface et on recommence, cette fois ci avec du 19mm comme discuté precedement:
Improvisation de l'atelier à l'extérieur (et puis c'est mieux pour couper le MDF)
Ca fait très bricoleur, mais avec mes montages je suis relativement droit
Découpe du fond en agglo de 15mm
Petit test :
Malgré ma manie pour être 100% droit, il me manque un 1mm !
Damned ! L'un des deux panneaux de la future coin box et plus court d'un millimètre et le fond est censé reposé dessus.
Pourtant je pensais qu'il était bon ?!  :?
Bon on va compenser
Un morceau de laminé d'1mm. est le tour est joué, après test je vais couper et coller le morceau en question sur le champ.
Essais des morceaux en 19mm
Reste plus qu'a ajuster tout ca, visser, coller et poncer l'arrondis  8)
Jeff
Super taf et vvraiment courageux d attaquer un projet comme celui ci.
Bravo  ^-^
La suite du stage CPO...
Petit essaie d'assemblage à blanc
Pour les renforts des arrondis, je vais coller la pièce suivante
Aller, je m'attaque à la plaque avant...
Visser dans le MDF, c'est mal, mais là je ne compte pas le rendre démontable et une fois n'est pas coutume  :D
Bon ca a l'air pas mal...à première vue
Mais, finalement c'est pas top. J'ai pas mis de colle et le MDF c'est légèrement décalé vers le haut lors du vissage  >:( (je vous disais visser dans le mdf, c'est mal)
On ne le vois pas sur la photo, mais il y a un interstice aussi entre le fond en agglo et le coté MDF.
Je vais sans doute tout démonter et coller avec des tasseaux.
speedsterharry
Je ne comprends pas la manie de certains de vouloir mettre des equerres et des vis pour leur borne, surtout si c'est fait à partir de MDF ! La colle à bois, c'est très bien et c'est très costaud. Il faut juste veiller à ne pas mouiller la colle par la suite, mais avec plusieurs couches de peintures, ca doit être réalisable.
Courage pour la suite
KodeIn
Vu ce qu'il compte faire de sa borne, je pense que la combinaison colle + vis est équerres n'est pas inutile.
Faut pas oublier qu'elle sera démontable pour la transporter facilement aux salons et autres expo.
La colle, il me semble que c'est très bien quand la borne ne bouge pas, mais que ça n'est pas super résistant aux déménagements.
En fait la partie que je réalise (le coté du CPO) n'est pas censé etre démonter, mais il est vrai que le reste oui (et puis c'est parfois plus pratique pour remplacer une pièce).
Pour le démontage je vous ferais une demo une fois la borne terminé  :D
Bon, je ne pouvais pas laisser ca comme ca se soir, j'ai donc courus dans mon atelier et démonté les équerres.
Application de la colle (je remettrait peut etre les équerres plus tard). Déjà, je veux que ca soit droit !! 8)
Montage Mc Giver approved
Les deux autre coté demande un serrage plus délicat, car il n'y a pas de coté opposé droit pour mettre un serre-joint  :?
Faut y aller avec des sangles sur ce coup là, les grosses équerres noire sont là pour maintenir droit les partie collées.
J'en profite pendant ce temps pour ajuster les panneaux de la coinbox et préparer du panneaux qui accueilleras la porte du monayeur.
Helas le temps (autoriser pour les WIPs) passe trop vite, encore une fois je n'ai pus avancer qu'un petit peu...mais chaque pas me rapproche un peu plus du final  :D
En attendant que le tout sèche bien, je me suis attaquer en ce WE ensoleillé (mais froid) à la coindoor.
Défoncer du MDF est très facile, mais extrêmement poussiéreux ! Même avec une aspiration, je vous conseil de faire ca dehors (à moins d'avoir un vrai atelier de menuiserie, bien sur)! Ce qui n'exclus pas un masque et des lunettes de protection.
Les coins de la porte sont arrondis,  pas évident à faire la première fois... :-[
Après quelques coups de lime pour l'ajustage...
Bon retour au CPO ce soir.
Je veux faire un montage "à blanc" pour ajuster toute les pièces avant de fixer tout ca !
